September 08, 2026, 07:15:02 pm
Hoffman Amps Forum image Author Topic: Can't see post.  (Read 29300 times)
Offline Blooze
Can't see post.
« on: August 13, 2022, 06:28:00 pm »
I made a new thread in the Tube Amp Building forum and can not see it.  Whenever I open it up there is just nothing on the page except the title. If I reply to it then I can see the original post.  I also can add attachments at all as well.  Happens on my phone as well as other browsers on my PC. Any suggestions?
Offline Blooze
Re: Can't see post.
« Reply #1 on: August 13, 2022, 06:28:16 pm »
same with this one.
Edit: Until I made this second post I was unable to see the first one.  Weird.
Tried to make a second test post in my one in the Amp Building area and no go for making it visible.
« Last Edit: August 13, 2022, 06:30:39 pm by Blooze »
Re: Can't see post.
« Reply #2 on: August 14, 2022, 07:22:01 am »
Offline Blooze
Re: Can't see post.
« Reply #3 on: August 14, 2022, 07:44:13 pm »
I see it just fine here
https://el34world.com/Forum/index.php?topic=29248.0
Worked for bit. Now I’ve made two posts in the GA18 thread that I can’t see. I don’t know if it’s the file s or what?  Tried to see on my phone, PC, and Chromebook to no success. If I host the pics at Imgur and BBCode then then the pics are fine.
Offline Blooze
Re: Can't see post.
« Reply #4 on: August 14, 2022, 08:52:27 pm »
Sluckey thinks it may be the Imgur link, but I only do that after it won’t take my posts with the direct file uploads.
Re: Can't see post.
« Reply #5 on: August 14, 2022, 11:42:55 pm »
....won’t take my posts with the direct file uploads.
Image size-How to reduce it.
https://el34world.com/Forum/index.php?topic=464.0
ALSO: what are you posting from Imgur? The image? Or the page?
Offline Blooze
Re: Can't see post.
« Reply #6 on: August 15, 2022, 07:19:19 am »
The BBCode. .
Re: Can't see post.
« Reply #7 on: August 15, 2022, 08:07:11 am »
Can't see Sluckey's reply
Offline Blooze
Re: Can't see post.
« Reply #8 on: August 15, 2022, 08:52:00 am »
I can run my images through photoshop and downsize to 1024 pixels wide, no problem. I'm using the BBCode link from imgur. Never had a problem with it anywhere else and I've only chose it because the files wouldn't seem to upload directly. COuld be the .diy files as well.
Maybe Hoffman can delete the two posts that seem to  have affected the thread?
Re: Can't see post.
« Reply #9 on: August 15, 2022, 09:00:14 am »
Don't use BBC codes in your post
Use the image links icon or upload from your computer
Offline Blooze
Re: Can't see post.
« Reply #10 on: August 15, 2022, 09:05:02 am »
I assumed it was doing the same thing. img]web address[/img  (can't put the outer brackets or it thinks it's code).
I apologize for causing so much grief.
Re: Can't see post.
« Reply #11 on: August 15, 2022, 09:14:05 am »
I don't know what was going wrong, but this is the best way
Use this icon to see the background code after you enter something
Offline Blooze
Re: Can't see post.
« Reply #12 on: August 15, 2022, 09:23:14 am »
Here's the code from the second post in that thread when checking the background code. In this instance it seemed to work as it should.  Makes me think that maybe the original png file size might be doing it when I try to direct upload the file?
Do I need to try and start another thread, or are you able to delete the last two posts of mine after bmccowan's last post?
Re: Can't see post.
« Reply #13 on: August 15, 2022, 09:30:01 am »
I don't see anything wrong with this post
No need to start another post
Offline Blooze
Re: Can't see post.
« Reply #14 on: August 15, 2022, 09:34:38 am »
There are 8 more posts after the last one of bmccowan's between myself and Sluckey. The only way I can see them is to try to reply. When the reply box is up then if I scroll down I can see those posts, otherwise they don't show up for some reason.  :dontknow:
Re: Can't see post.
« Reply #15 on: August 15, 2022, 09:38:18 am »
Ok, I see the bottom of the forum is missing below the last post
I will go see if if there are any illegal characters in that post
Re: Can't see post.
« Reply #16 on: August 15, 2022, 09:45:54 am »
Hard to figure out what is wrong with  that post
If you want to start a new one, go ahead
I will delete the old post when you are ready
Offline Blooze
Re: Can't see post.
« Reply #17 on: August 15, 2022, 09:53:31 am »
Feel free. It's weird.  That's the same thing that happened to the first thread, too.  So it's something on my end. I'll make sure to resize my images to 1024 pixels wide as well, although I have trouble reading the values in the schematic at that size.
I wonder if you were able to delete the attachments I put in the last posts if it would fix it?
Offline Blooze
Re: Can't see post.
« Reply #18 on: August 15, 2022, 09:58:37 am »
Or maybe deleting all the posts past the last one by bmccowan?
Re: Can't see post.
« Reply #19 on: August 15, 2022, 10:02:14 am »
Too late
Offline Blooze
Re: Can't see post.
« Reply #20 on: August 15, 2022, 10:14:13 am »
Again, I apologize for all the hassle.
Thanks for all your help!
