August 07, 2026, 07:41:37 pm
Hoffman Amps Forum image Author Topic: Voltage drop with power tubes installed  (Read 5986 times)
Offline Ledvedder
« on: August 24, 2022, 08:41:07 am »
Hi guys,
I'm troubleshooting a 1987/2204 that I've built. I used a Modulus plexi kit, but I'm building it to 2204 spec. For the power section, I've used Ceriatone's 2204 wiring layout. I'm getting a significant voltage drop when power tubes are installed. I've recorded the readings on all el34 socket pins. The top values are without power tubes, with preamp tubes. The bottom values are with both power and preamp tubes installed. I'm getting roughly the same readings as pins 2 on pins 7.
Any ideas where I should start?
Offline Cirrus
Re: Voltage drop with power tubes installed
« Reply #1 on: August 24, 2022, 09:56:12 am »
Do the readings change if you pull the phase inverter? Just wondering if there's any oscillation that might cause the readings to be off...
« Reply #2 on: August 24, 2022, 12:45:40 pm »
Light bulb limiter in circuit?
Offline Ledvedder
« Reply #3 on: August 24, 2022, 01:08:52 pm »
I'm guessing the light bulb limiter was causing issues with my voltages. Now I'm able to get power tubes biased to 32 and 36mV respectively. Plate voltage is then 332v.
Now I'm getting a super annoying hum and a faint high pitched squeal through the speakers that I'll have to figure out.
« Reply #4 on: August 24, 2022, 05:24:43 pm »
The bulb wattage you had in was fine for ‘no valves’ testing. But higher power is needed for the next stages, testing it with valves, and then under load.
Once the build and valves have then proved themselves good, it’s safe to continue testing / troubleshooting without light bulb limiter.
Offline Ledvedder
« Reply #5 on: August 24, 2022, 10:37:34 pm »
Yep, I got all voltages up to acceptable values after I removed the bulb limiter. I didn't realize it would cause that much of a drop. I'm getting around 432v on the plates. Now I'm troubleshooting other issues with the preamp. I'm getting a hum that increases with the MV, but no guitar signal.
« Reply #6 on: August 25, 2022, 04:42:43 am »
Take VDC readings on all HT supply nodes, plates, and cathodes of all tubes, and report back.
And do a pop test on all grids and plates
« Reply #7 on: August 25, 2022, 05:18:10 am »
What could possibly go wrong with that plan???   :icon_biggrin:
I suspect a wiring error.
Offline Ledvedder
« Reply #8 on: August 25, 2022, 10:53:36 am »
I posted wrong information.
« Last Edit: August 25, 2022, 11:23:49 am by Ledvedder »
