August 07, 2026, 08:42:38 pm
Hoffman Amps Forum image Author Topic: 82 JC120 - desperado  (Read 3959 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: August 25, 2022, 06:59:57 pm »
Long time - hope all is well with you guys!
Have an older 120 on the bench. Amp had a blown speaker and rectifier.  After replacing the rectifier and refreshing the 4 output transistors, there is still an underlying issue. One of the power amps has 30vdc present on the orange brown output pair.  No bueno. I’m out of my depth with solid state things like this, but took it in to help a long time customer.    Not sure where to look next. Any help appreciated!
FDeSalvo,
Principal Engineer & Owner,
Offline glass54
Re: 82 JC120 - desperado
« Reply #1 on: August 25, 2022, 08:59:49 pm »
Hi fdesalvo,
I have fixed a few of these in past decades.
We don't know which the orange brown pair is ie NO INFO on schematic.
I'd suggest a DC offset problem, so I would be suspicious of a leaky C16 or C49 (depending on your problem Power amp).
It's an aged 10uF 16V Electro. I would recommend a new 10uF 25V or higher Bipolar and replace both.
Next I would consider checking C24 (C63) and as best you can measure DC Volts around Q6 and Q7 (Q13 and Q14).
You have 2 power amps, and one good one, you are lucky  :laugh: Go for it with a good multimeter.
Regards
Mirek
"To measure is to know"
Offline fdesalvo
  • "...I can walk!!"
« Reply #2 on: August 25, 2022, 09:20:45 pm »
Ty!  I have to bite the bullet and study up on these silicon demons lol.
FDeSalvo,
Offline fdesalvo
  • "...I can walk!!"
« Reply #3 on: August 26, 2022, 12:13:47 pm »
Apologies for the morose update, but I’ve decided to return the amp to my friend. I’m out of my depth here and with family conditions and my recent hand surgery, I just don’t have the cycles necessary to learn on this job. I appreciate the help however.
« Last Edit: August 27, 2022, 12:05:08 am by fdesalvo »
FDeSalvo,
