August 08, 2026, 09:03:29 am
Hoffman Amps Forum image Author Topic: JMI Secrets - Circuit Borrowed from Hammond Vibrato ???  (Read 7163 times)
« on: August 29, 2022, 12:07:21 pm »
Does someone knows which is the Hammond circuit that was stolen ??
Re: JMI Secrets - Circuit Borrowed from Hammond Vibrato ???
« Reply #1 on: August 29, 2022, 01:34:57 pm »
That Vox vibrato circuit was copied from a Wurlitzer organ, not a Hammond organ. See
     http://sluckeyamps.com/misc/Dorf_TheWurlitzerVibrato.pdf
« Reply #2 on: August 29, 2022, 03:05:18 pm »
100%
Sluckey doesn't need me to second-guess his statements, but I agree this is an error in Elyea's otherwise outstanding book on JMI amps.  The circuit was lifted directly from Wurlitzer organs.
« Reply #3 on: August 29, 2022, 03:58:48 pm »
Many Thanks Friends
At the moment I'm not able to read the PDF because I'm on the phone and seems I must be on the PC to open the file
Thanks again
EDIT: Problemi solved, I can read the whole text
« Last Edit: August 29, 2022, 04:04:17 pm by kagliostro »
« Reply #4 on: August 29, 2022, 08:34:41 pm »
I've read that Gibson got it from Wurlitzer and Vox took it from Gibson.
« Reply #5 on: August 29, 2022, 11:56:08 pm »
IIRC, the early Hammond pitch shifting scheme was electromechanical, with a later scheme that was all electronic employing saturating core inductors.
Steve, wasn't your warbler project based on the saturating core inductor type?
--Pete
« Reply #6 on: August 30, 2022, 06:24:41 am »
--Pete
Yes. And the earlier Hammonds did use a motor driven rotating scanner type vibrato.
« Reply #7 on: August 30, 2022, 06:54:32 am »
Something that rensambled a circular saw ?
« Reply #8 on: August 30, 2022, 07:22:14 am »
Scanner looks like this...
     http://theatreorgans.com/hammond/faq/a-100/fig-28.jpg
Theory of operation. Scroll down near the end of page...
     http://theatreorgans.com/hammond/faq/a-100/a-100.html
« Last Edit: August 30, 2022, 10:02:47 am by kagliostro »
« Reply #10 on: August 30, 2022, 10:22:50 am »
This is what I was remembering
That is the tone wheel. It generates the sine wave tone you hear when you press a key. For example, pressing the middle C key activates a switch that selects the proper tone for a C note. Quite different from the vibrato scanner. The vibrato circuit occurs farther down the signal path. When that C tone passes through the scanner circuit, the frequency is shifted a little bit below C and a little bit above C, producing the vibrato effect.
That's a very simplistic explanation and may not be totally accurate, but should give you an idea of what's going on.
« Last Edit: August 30, 2022, 10:25:09 am by sluckey »
« Reply #11 on: August 30, 2022, 12:03:40 pm »
Oh, I understand
« Reply #12 on: August 31, 2022, 05:44:04 am »
We may never be sure how something got swiped.
However, it's worth pointing out that before Dick Denney enters the scene that Tom Jennings is in business selling keyboards/organs.  We might guess Wurlitzer's vibrato was swiped directly on the basis of JMI's business-focus before the AC-amps enter the picture.
