September 08, 2026, 07:29:53 pm
Hoffman Amps Forum image Author Topic: Since It Seems To Be Champ Amp Month...  (Read 11626 times)
« on: August 29, 2022, 09:25:39 pm »
Dusting this project off...My spin on a 5E1 - EL34 output tube. Going to sub in a 12BZ7 to shoot for maximum gain with this ckt.
I haven't built a Champ into a chassis/cabinet yet. No Champ amp shall go unmodified. I may actually build this one.  :icon_biggrin:
Fairly quiet amp, even on the breadboard.
--Pete
Re: Since It Seems To Be Champ Amp Month...
« Reply #1 on: August 29, 2022, 09:27:34 pm »
El Champ on the BB
« Reply #2 on: August 29, 2022, 11:21:28 pm »
Impressive breadboarding going on there
« Reply #3 on: August 29, 2022, 11:38:26 pm »
Thanks Pete!
--Pete
Offline Williamblake
« Reply #4 on: August 30, 2022, 02:10:28 am »
Very nice breadboarding, indeed. Is the a special name for that kind of terminals?
« Reply #5 on: August 30, 2022, 02:36:08 am »
Two row barrier strips -or- Double row barrier strips. The ones I use are on .375" (9.5mm) centers. The ones I use specifically are becoming increasingly difficult to find, as I require what's called a wire clamp screw, or sometimes also called a wire captive screw. To circumvent, I buy the 20 position model and buy the wire clamp screws from another source. beware that some barrier strip screws are metric, most are 6-32 screws, but some are also metric, typically M3.5x.06x6mm screw - Links below to a source for both metric and inch pattern clamp screws and barrier strips.
https://www.mpja.com/Pack-of-10-6-32-Screws-with-wire-clamp-for-Power-Supply/productinfo/31980%20HD/
https://www.mpja.com/Pack-of-10-Screws-m35-06-with-wire-clamp-for-Power-Supply/productinfo/31981+HD/
Metric:
https://www.allelectronics.com/item/ts-210/dual-row-barrier-strip-20a-10-circuit/1.html
Inch:
https://www.newark.com/multicomp/mc24323/terminal-block-barrier-20-position/dp/14N5652?gclid=CjwKCAjw6raYBhB7EiwABge5KhNcWqvtK1FqWQL7lvPrKVuZ08gJ5echaxTDnBm6am8SBaxo3Rrq8BoCOb8QAvD_BwE&mckv=_dc|pcrid||plid||kword||match||slid||product|14N5652|pgrid||ptaid||&CMP=KNC-GUSA-GEN-Shopping-PMAX-Med-ROAS
https://www.digikey.com/en/products/detail/molex/0387700320/3301061
Google search for "two row barrier strip" and you'll have more hits than you'll have time to sort through.
--Pete
« Reply #6 on: August 30, 2022, 09:23:58 am »
That IS the most adorable little breadboard I have ever seen  :huh:
You should tell the guy who labels your BBs that you are using an EL34 this time.  :icon_biggrin: Is he the same guy who cuts your lawn?
Offline 66Strat
« Reply #7 on: August 30, 2022, 09:42:52 am »
GREAT IDEA for bread boring. I bought one of those strips yesterday at the big box store to fix a control wiring mess by the A/C technician.
Regards,
JT
« Reply #8 on: August 30, 2022, 12:42:44 pm »
....I bought one of those strips yesterday ...to fix a control wiring mess by the A/C technician.
I got a "trailer junction box"--
https://www.amazon.com/MICTUNING-Way-Electrical-Trailer-Junction/dp/B07QDQRX7P
7 studs is enough for most heat/AC thermo-control wiring, box protects against paint-cans and dead amps shoved against the furnace. Run of CAT-6 net-cable from the furnace computer terminals to this box outside and up at working level (my furnace PCB is hardly off the floor). Side-run for the hour meter and condensate pump shut-down.
« Reply #9 on: August 30, 2022, 05:23:49 pm »
Nah, he's the guy that plays the stratocaster while on fire...   :icon_biggrin:
--Pete
Offline 66Strat
« Reply #10 on: August 30, 2022, 06:39:48 pm »
I'm replacing a Carrier thermostat. It's a two board control; one at the furnace, and a separate board at the thermostat. I re-purposed the cover for the board at the furnace to house the terminal strip.
Regards,
JT
« Reply #11 on: August 30, 2022, 07:05:14 pm »
my Champ'ish perversion
I didn't use HIGHGAIN tubes so there's more than 2  :laugh:
always ASUME my schematics have flaws (it may be a rev or 6 behind also)  :icon_biggrin:
« Reply #12 on: August 30, 2022, 08:04:30 pm »
Now that's a real man's output tube there.
I think DL should have to call his the El Chumpo  (after the weak younger skinny cartel brother)
« Last Edit: August 30, 2022, 08:06:55 pm by SILVERGUN »
« Reply #13 on: August 30, 2022, 10:13:12 pm »
No but 184=104976 overall gain of your preamp;
beats my lowly pair of triodes... 502=2500 - you win!   :cussing:
However, I have 1 less tube to wire filaments to, so I win!    :blob8:
--Pete
« Reply #14 on: August 31, 2022, 04:08:55 am »
 :laugh:
IIRC the last stage became a CF on the 2nd tweak-round
and
I did catch the big tube bug from some of your "lets see what a pair of 120's runnin hot....." experiments
win or lose, it's all about stealin circuits  :icon_biggrin:
(the pre-is a molested steal from Steves juke-box build)
this one did make it into the wild, always a good indicator, I got close enough
« Reply #15 on: August 31, 2022, 03:21:55 pm »
Ha! EL Chumpo? No! KT ChampMacho Seņor!
« Reply #16 on: August 31, 2022, 04:44:01 pm »
Looks like you've got more cojones than el buen sentido there Ese
I can still see the EL in the pic so I know this was just a photo op = busted
« Reply #17 on: August 31, 2022, 05:05:14 pm »
looks like there's someone stuck inside your tubes trying like hell to get his magic rectangle to help escape  :icon_biggrin:
buenos no-chez seenyourz
Offline Electron Tornado
« Reply #18 on: September 02, 2022, 01:31:09 pm »
El Champ on the BB
Nice breadboard! Have you seen these?
https://www.ebay.com/itm/152240765977
{edit- trimmed eBay tracking data -- PRR}
« Last Edit: September 02, 2022, 03:46:26 pm by PRR »
Who is John Galt?
« Reply #19 on: September 02, 2022, 01:53:25 pm »
El Champ on the BB
Yes, and thanks!
--Pete
« Reply #20 on: September 02, 2022, 02:14:39 pm »
El Champ on the BB
Yes, and thanks!
--Pete
I think you meant to say "Thanks, and yes!"
« Reply #21 on: September 02, 2022, 03:27:01 pm »
