October 05, 2026, 10:03:36 pm
Hoffman Amps Forum image Author Topic: Vibrato channel low volume in Bandmaster  (Read 6384 times)
Offline jim
« on: September 10, 2022, 12:29:35 pm »
The normal channel is normal volume and clean.  The power amp is working fine.  Trading pre-amp tubes between channels shows the problem stays with the vibrato channel.  There is a hair of distortion whenvibrato volume is 10 but volume is real low.  Voltages on the tube socket look normal--235V on 1,6 and 1.6V on 3,8.  I replaced the bypass caps on the cathodes.  Funny thing is when I opened the chassis I founda 1/4 inch plug tip rolling around inside.   Also reverb and trem works OK on the vibrato channel--not modded for both channels.  How should I chase down the problem?  Thanks, Jim
Offline jordan86
Re: Vibrato channel low volume in Bandmaster
« Reply #1 on: September 10, 2022, 12:41:41 pm »
I have a 65 Showman and ran into this same issue when I got it a few years ago. I was informed here by more experienced guys that this is somewhat normal due to the load of the vibrato circuit on that channel. On my showman, I need to be at like 6-7 on the volume to match 4 on the normal channel.
Offline jim
« Reply #2 on: September 10, 2022, 12:45:11 pm »
Actually trem does not work but I can see the roach flashing.   This volume is is super low barely audible. Jim
« Reply #3 on: September 10, 2022, 01:00:58 pm »
Just to be clear, it’s a Bandmaster Reverb?
How about the V4 voltages? Including the grids.
Offline jim
« Reply #4 on: September 10, 2022, 03:43:53 pm »
OK voltages are 231V 1,6;  0V on grids;  1.8V on cathodes.   But when I simply touched pin 6 with the test lead there was the usual static and then the channel suddenly came alive.  What did I do--should I remelt the solder and call it a day?  I dont't understand.  But I appreciate your insight.  Jim
Offline jim
« Reply #5 on: September 10, 2022, 03:53:55 pm »
Likely corrosion and fifty years of grime on the tube socket.  Ill clean it up.  Thanks!
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #6 on: September 11, 2022, 05:28:53 pm »
remelt the solder and ...
Do that not only for that part of the amp , but do a check on everything, is the amp old?
https://soundcloud.com/ukiuki
