August 29, 2026, 08:27:28 pm
Hoffman Amps Forum image Author Topic: Ampeg tranny black cover epxy  (Read 6307 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: September 13, 2022, 05:58:09 pm »
Hi amigos,
I removed the short tranny from its black cover
(Old Ampeg ) and I am ready to put a new in.
My question is: what kind of stuff should I use  to replace the black tar that holding the old one inside ?
P.S.: call me Alvin.
Offline vampwizzard
    • Walbertedwards.com
Re: Ampeg tranny black cover epxy
« Reply #1 on: September 14, 2022, 06:04:48 pm »
it should've been epoxy resin, or potting compound.
  • MAKE LOVE NOT WAR
« Reply #2 on: September 14, 2022, 06:26:02 pm »
I was going to use silicone, just to hold the new tranny in the cover of that B15N. I had to use a propane torch to melt that black stuff in order to remove the damaged tranny from the black box.  In doing so,  I burnt the black coating so I had to sand it entirely to metal before  priming it ( automotive grey primer). I was really excited to fit the new tranny in but Linda just called me for supper and the evening took another path....
This morning, after 3 expressos to help swallow
my half inch peanut butter spreaded on 2 full grain toasts, I went down to my shop and.realized the new tranny wouldn t fit in the newly painted enclosure......gee whizzz
  • MAKE LOVE NOT WAR
« Reply #3 on: September 14, 2022, 06:36:03 pm »
now I know how to  easily remove a b15n tranny from its enclosure but I have to check the measurements BEFORE ordering the new transformer. I had a transformer in stock that would fit in but with plate supply of only 300V.
Colas
« Reply #4 on: September 14, 2022, 08:29:09 pm »
Epoxy in transformers is rare or never. The unyielding fill tends to break fine wire.
Roofing tar is readily available and appropriate. Heat it up, don't start a fire. Solvent thinner is probably a bad idea unless you know all the varnish and plastic in the transformer can stand it. If you can get it thin enough to stir, clean coarse sand in large quantity improves the heat transfer. (See and open UK job-site 110VAC yellow transformers.)
« Reply #5 on: September 15, 2022, 01:04:43 am »
I'll avoid the use of epoxy (near impossible to go back if you put It on), also silicon will be really difficult to manage if there are problems
Obviously the better will be to don't use any material, however PRR Is absolutely right, roofing tar will be the right way to do It, in the future, if you have any problem you'll be glad you followed his council
« Last Edit: September 15, 2022, 01:07:15 am by kagliostro »
  • MAKE LOVE NOT WAR
« Reply #6 on: September 15, 2022, 04:03:27 pm »
If it would fit iin I would jam it in place  with.copper pipes or any heat proof material.
Anyway the enclosure is screwed on the chassis , the tranny can t go away
My Linda can go away though she promised to stay with me. I could put her in a box , no ?
I stop right here. She.might read this.post...
Hey honey, I love you don t go away !!!
Offline vampwizzard
« Reply #7 on: September 20, 2022, 10:47:23 am »
We used it all the time for low voltage applications. Fully encapsulated transformers are common. Usually we put a silica mix with the epoxy for heat dissipation.
