September 13, 2026, 05:49:47 pm
Hoffman Amps Forum image Author Topic: Signal strength for testing  (Read 5305 times)
Offline acheld
« on: September 15, 2022, 02:40:52 pm »
I want to follow the signal through a preamp section with my 'scope, mostly to see for myself what happens to the signal after each triode.
The question is:  what should be the signal strength I send?   I tried to measure the output of one of my guitars, but I'm questioning the results.
Using a Fluke 117 in AC V Max/Min function, six string strum is at about 80mV;  the A string comes in at about 30mV.  This is from a stock Ibanez single humbucker measured at the amp's input jack. Seems low to me, but . . .
What signal strength are you 'scoping with?
Re: Signal strength for testing
« Reply #1 on: September 15, 2022, 06:37:29 pm »
1KHz, 100mV, sine wave is easy to remember.
« Reply #2 on: September 16, 2022, 02:40:57 am »
I've found 800hz is more pleasing to my ears.
once i've run the test signal and recorded the stages, I typically leave the scope connected to the speaker, then slowly bring up the test signal til the scope display just starts to distort.
measure n note the signal amplitude as "max clean input"
that is the value I use for da math
Offline acheld
« Reply #3 on: September 16, 2022, 10:15:17 am »
Many thanks!
« Reply #4 on: September 16, 2022, 10:49:27 am »
FYI my Les Paul, which has vintage PAF type rather than hot pickups (Burstbuckers I think), puts out 2Vpk on initial pick attack.
If an input stage is underbiased, it’ll cause noticeable clipping there.
« Last Edit: September 16, 2022, 10:51:52 am by pdf64 »
Offline acheld
« Reply #5 on: September 18, 2022, 09:53:59 am »
Whoa.  I think that would clip on any of my amps!
