August 29, 2026, 09:11:29 pm
Hoffman Amps Forum image Author Topic: type of potentiometers  (Read 6475 times)
Offline rafaelctt
« on: September 27, 2022, 02:10:09 pm »
What type are these HD or J-terminated potentiometers?
Thank you
Re: type of potentiometers
« Reply #1 on: September 27, 2022, 07:06:22 pm »
It seems that J means a J-taper.  Don't know what HD means yet.
J taper is a softer audio taper where you have around 30% resistance at noon, as opposed to the 10 to 15% found in more conventional audio taper pots.  You could think of it as an in-between the linear and audio taper.  I've seen it in some Fender amp schematics.
If you are familiar with Duncan's tonestack calculator, you'll see there are two kinds of audio taper in the program, "A" and "B".  The former corresponds to the "J" taper, while the latter corresponds to the sometimes called "A" or log or audio taper.
Logged
STM
runoffgroove.com
« Last Edit: September 27, 2022, 07:10:11 pm by mresistor »
« Reply #2 on: September 28, 2022, 04:26:18 am »
The few 999k HD late 70s / early 80s pots from Fenders that I’ve checked are basically 1M linear.
It seems a strange choice, but the justification may be that these are loud stage amps, and also it makes them stand out on the shop floor. eg if they’re this loud on ‘2’ then think how loud they’ll be at ‘10’.
Offline d95err
« Reply #3 on: September 28, 2022, 06:55:23 am »
(rant warning!)
Fender’s obsession with linear taper colume controls is just wierd.
When I’ve had the misfortune to encounter a Hotrod Deluxe on stage, I’ve found them virtually unusable. If you even breathe in the direction of the master volume knob, the level changes to either inaudible or frickin’ way too loud. Almost impossible to get a balanced level.
I would never buy an amp with that kind of design flaw.
(rant over, sorry!)
Offline rafaelctt
« Reply #4 on: September 28, 2022, 10:04:26 am »
And being of volume, wouldn't it be better to replace it with 1 M Audio (logarithmic)?
