August 29, 2026, 08:27:54 pm
Hoffman Amps Forum image Author Topic: Master volume on Musicmaster amp  (Read 6767 times)
Offline isaac_teller
« on: October 03, 2022, 02:19:47 am »
Hello. How would I put a post phase inverter(interstage transformer) master volume on this amp(Lamar type)? There are no grid leak resistors. I tried a cross-line 1 meg pot but it's only really effective from 0-1.5. Thank you.
https://music-electronics-forum.com/filedata/fetch?id=871806&d=1636912611
Offline Latole
Re: Master volume on Musicmaster amp
« Reply #1 on: October 03, 2022, 02:59:56 am »
« Last Edit: October 03, 2022, 03:04:20 am by Latole »
Offline Leevi
    • Rikstone
« Reply #2 on: October 03, 2022, 05:14:31 am »
Try 250K Audio pot
/Leevi
Offline Latole
« Reply #3 on: October 03, 2022, 05:26:04 am »
Pot must be a A audio not B.
I did not say a pot will work !
« Last Edit: October 03, 2022, 08:47:46 am by Latole »
« Reply #4 on: October 03, 2022, 08:09:29 am »
Thanx. I'll give it a try.
« Reply #5 on: October 03, 2022, 08:28:57 am »
I wonder if that PI transformer will be happy when that crossline MV puts a short across the secondary.   :think1:   :dontknow:
« Reply #6 on: October 03, 2022, 08:37:39 am »
I really don’t see the point of a master volume here. There’s only 2 common cathode gain stages in cascade feeding it, the second inly has a 15k anode load.
That boils down to ‘unless using an external pedal, there won’t be much if any preamp overdrive available’.
Whatever, a LarMar / type 2 master is just a volume control potential divider across each leg of the interstage transformer.
Imagine the winding is a guitar pickup and consider how a volume control is arranged there.
« Last Edit: October 03, 2022, 08:41:11 am by pdf64 »
« Reply #7 on: October 03, 2022, 09:07:41 am »
How about adding another gain stage(100K/1.5K) before the interstage in addition to the master?
« Last Edit: October 03, 2022, 09:18:38 am by isaac_teller »
Offline dwinstonwood
« Reply #8 on: October 03, 2022, 09:20:19 am »
This preamp has worked great for me. It has the "extra" gain stage, and an extra gain/volume pot. You don't need the full TMB tone stack, if you don't want it.
Bypass the third cathode if you want more gain.
« Last Edit: October 03, 2022, 09:23:34 am by dwinstonwood »
« Reply #9 on: October 03, 2022, 12:01:07 pm »
The 15K on the IT primary. Replace with 25K Audio wired as rheostat so "10" is 25k, "5" is a few K, and "0" is of course near zero.
However I don't think this is a good amp to hack up. It is what it is, is unique, and may eventually be recognized as "not just another Fender Champ/Deluxe/Twin".
