August 29, 2026, 08:28:46 pm
Hoffman Amps Forum image Author Topic: Input resistance measurements  (Read 7213 times)
Offline Mr.Death
« on: October 07, 2022, 04:41:21 pm »
I've finished up mods to my Traynor Custom Special YBA3 and find the amp to be rather tame for the mods I have done so I started taking resistance measurements to see if everything is good starting at the front end. For the low input I get 138K which is good(so Ive read) but the Hi channel only reads 220k. Attached is a schematic. The front end is like a JCM800 with the 1 meg grid leak resistor and the 68K grid stoppers. Should my reading for the hi channel be 1Meg (ish)? Thanks and again sorry for my ignorance. Ive researched this all morning and have come up short so I thought I'd ask the pros. Thanks
Rick
Offline Mr.Death
Re: Input resistance measurements
« Reply #1 on: October 07, 2022, 05:54:26 pm »
Just need to know what the high jack's resistance should be from tip to pin 7 of V1 as well as the lo inputs resistance. Thanks.
« Reply #2 on: October 07, 2022, 06:53:37 pm »
68k
68k+68k//470k=59k4
Expected value is 470k+68k=538k
Offline Mr.Death
« Reply #3 on: October 07, 2022, 07:12:29 pm »
Where are you getting the 470K from? I used a 1 meg resistor
Offline Mr.Death
« Reply #4 on: October 07, 2022, 07:20:09 pm »
Should hi input resistance read 1meg plus 68k= 1.68meg?
Thanks.
« Reply #5 on: October 07, 2022, 07:36:19 pm »
No. 1M + 68K is 1.068M. This is resistance between tip and ground.
Resistance between tip and pin 7 is 68K.
Offline Mr.Death
« Reply #6 on: October 07, 2022, 07:47:00 pm »
Well then somethings wrong with my wiring as my results are different. My wiring...Also just a note.... I didnt touch the jack wiring, was like this when I got it. Looks like the jacks are touching in a spot.
« Reply #7 on: October 07, 2022, 08:10:07 pm »
I should clarify. The above numbers apply if you have a dummy plug inserted into the hi jack. With no plug inserted you should measure zero ohms between tip and ground and you should measure 68K between tip and pin 7.
Offline thetragichero
« Reply #8 on: October 07, 2022, 09:51:55 pm »
sluckey has a pdf amp scrapbook on his site. i always copy the fender jack wiring from it, although i like to have the 68k grid stoppers soldered directly to the tube pin
« Reply #9 on: October 08, 2022, 05:09:26 am »
You hadn’t noted any deviations from the schematic you included, which shows 470k, not 1M.
« Last Edit: October 08, 2022, 10:21:01 am by pdf64 »
Offline Mr.Death
« Reply #10 on: October 08, 2022, 08:56:50 am »
Great! THanks for the reply. I insrted a dummy plug and got the numbers I was looking for. Perfect!
« Reply #11 on: October 08, 2022, 03:10:34 pm »
It is not clear who put that very pretty "M" on the drawing, but Death's text does reference "1 meg".
« Reply #12 on: October 08, 2022, 03:23:21 pm »
Oh yeah, the cursive italic script used didn’t register with me  :icon_biggrin:
