September 16, 2026, 12:03:20 am
Hoffman Amps Forum image Author Topic: A250k solid shaft push/pull pot  (Read 4188 times)
Offline Esquirefreak
« on: October 10, 2022, 09:26:03 am »
Does anyone here know where to find good quality p/p 250k pots with steel/brass/metal solid shafts? Looks like most pots are either splined shafts or concentric dual gang pots. At least, here in Europe, that is.
I've been experimenting with treble attenuation and would like to have this option on a switch. Two series caps with the switch between them would hopefully avoid DC presens and increase the switch longevity.
This in combination with a 47pF bright cap on the volume pot makes for interesting combinations, because the high mids get scooped out a bit.
/Max
Re: A250k solid shaft push/pull pot
« Reply #1 on: October 10, 2022, 01:11:23 pm »
That's still going to pop. Leaving the ends of caps floating is such an undefined (bad idea) state that my circuit simulator won't even think about it.
I think what you want is this.
Offline isaac_teller
« Reply #3 on: October 10, 2022, 04:57:23 pm »
Of course, that makes sense. Thanks!
/Max
