September 15, 2026, 08:33:41 am
Hoffman Amps Forum image Author Topic: Burnt screen grid resistor, my mistake.  (Read 4494 times)
Offline Mr.Death
« on: October 14, 2022, 02:27:24 pm »
I was checking bias today with my new probe and when I reinstalled the tube I installed the tube incorrectly, the key was off by one pin. My mistake and I'm ashamed of it  :sad2:.....  :BangHead: I ended up burning one screen grid resistor in the process. When I inspected the amp I noticed R30 (1K 20watt sand resistor) was hot to the touch and a little discolored. It measured fine with the multimeter. I ordered the 2 47R resistors for the screen resistors. Should I also replace the 1K20watt? Like I said it still measures within spec. Leave it? Thanks. Schematic for reference. Resistors circled.
« Last Edit: October 14, 2022, 02:31:00 pm by Mr.Death »
Re: Burnt screen grid resistor, my mistake.
« Reply #1 on: October 14, 2022, 06:02:10 pm »
I never like to leave burned or overheated components in an amp.  What happens when it is under load again?    Just replace it as they are cheap.
Offline Mr.Death
« Reply #2 on: October 14, 2022, 07:25:46 pm »
Just happened this morning and Ive yet to replace the components. Having a hard time locally finding a sand cement resistor for the 1K 20 watt.
Offline Mr.Death
« Reply #3 on: October 15, 2022, 01:29:41 pm »
I replaced the burnt 47r resistor and everything works as it should, lesson learned.
« Reply #4 on: October 15, 2022, 02:29:59 pm »
How did you do that unless the key on the tube was missing?
Glad the damage was minor.
