September 16, 2026, 04:17:41 am
Hoffman Amps Forum image Author Topic: Matchless bulbs?  (Read 7602 times)
Offline joesatch
  • save me from myself.
Matchless bulbs?
« on: October 17, 2022, 10:03:45 pm »
what's the purpose of these bulbs in the chassis?
Offline Latole
Re: Matchless bulbs?
« Reply #1 on: October 18, 2022, 03:26:35 am »
Did you see the illuminated logo or front panel  ?
Google ;Matchless illuminated face plate.
https://www.matchlessamplifiers.com/support
_____________
 FAQ
How do I replace the logo lightbulbs?
There are four lamps used to illuminate the logo.
If the logo appears unevenly lit one of these lamps is probably out. The lamps are located in a reflector assembly known as a light box.
The light box is positioned just above the speaker(s) and is removed by removing the securing screws and disconnecting the two wires that supply power from the chassis.
The wires are connected with quick disconnect spades. Use a long screwdriver for easy access to the screws. If the amplifier is configured as a head, the chassis must be removed first.
*Do not attempt to go through the logo.*
_____________
How do I replace the control panel lightbulbs?
There are five lamps used to illuminate the front panel of the amplifier.
When one of these lamps requires replacement, the entire chassis must be removed from the cabinet.
To do this, first remove the power cord from the amplifier.
Then remove the back panel by loosening the hold-down screws.
Remove the two wires that provide power to the logo. These are pull-off connectors.
If the amplifier is a combo, disconnect the speaker plug located next to the fuse holder.
Carefully remove the four screws on the top of the cabinet while supporting the weight of the chassis with one hand. Slide the chassis out to replace the bulbs.
To re-install the chassis, simply reverse the process.
« Last Edit: October 18, 2022, 03:29:10 am by Latole »
Offline joesatch
« Reply #2 on: October 18, 2022, 06:18:59 am »
for the logo?  that's nuts
Offline Latole
« Reply #3 on: October 18, 2022, 06:23:00 am »
Does this answer your question ?
« Reply #4 on: October 18, 2022, 08:20:35 am »
curtesy lights for working under the hood?
chassis warmer for even heating?
where do the wires lead, someone had a design to use incandescent bulbs as a "bias select" for an SE biased amp.  The less lights, the hotter it's biased
Offline bmccowan
  • Better builder than player
« Reply #5 on: October 18, 2022, 09:10:21 am »
It's a Matchless - expect things to be different.
Mac
John Prine
Offline joesatch
« Reply #6 on: October 18, 2022, 01:25:23 pm »
i am willing to bet they do more than illuminate the front panel (that reason is probably a diversion). They might reduce interference as the bulbs provide a circuit around the chassis which could block EMI
« Reply #7 on: October 18, 2022, 01:34:24 pm »
Another quotable quote. Good one!    :l2:
« Reply #8 on: October 18, 2022, 01:56:42 pm »
Yeah, they help justify the price of the amp
Offline RadioComm
« Reply #9 on: October 18, 2022, 01:57:27 pm »
I inherited my Father-in-Law's late 60's stereo receiver. Highbred receiver with tube preamp and transistor power amp. It also has a rail of #47 light bulbs to provide the back light to the radio dial panel.
Offline Latole
« Reply #10 on: October 18, 2022, 01:58:35 pm »
I inherited my Father-in-Law's late 60's stereo receiver. Highbred receiver with tube preamp and transistor power amp. It also had a rail of #47 light bulbs to provide the back light to the radio dial panel.
It is very common .
Offline dwinstonwood
« Reply #11 on: October 18, 2022, 02:08:23 pm »
I sort of think they're installed upside down. In order to illuminate the Matchless logo, the bulbs need to be under/outside the chassis.
Offline Latole
« Reply #12 on: October 18, 2022, 02:42:44 pm »
Reply 1 :  Answer from Matchless;
« Reply #13 on: October 22, 2022, 07:57:17 am »
i am willing to bet they do more than illuminate the front panel ...
No, they light up the front panel.  The panel was black-over-clear IIRC, was engraved through the black to leave the clear.  Then lightbulbs sprinkled through the chassis would turn on when the power switch is thrown, and light up the engraved legend on the panel.
I went Ampeg's route making a light-up faceplate: engrave the acrylic, then light from the edge.
I have a reverse-engraved panel (engraved side against the chassis), then put a few blue LEDs against the right edge.  The light transmits through the clear acrylic then is bent out to the viewer's position at the engraving.  The amp I used it on is noted here.
The photo is from a phone camera, and the LEDs tend to overdrive the sensor.  In person, it's a more subdued blue, and not as bright/intense.  I could add LEDs to the other side of the panel & tinker the dropping resistor to the LEDs to tune the brightness & balance, but just haven't bothered.
Offline Latole
« Reply #14 on: October 22, 2022, 08:16:35 am »
Almost( if not all )  no amps use that bulb and there are no EMI
Offline 66Strat
« Reply #15 on: October 22, 2022, 10:25:03 am »
Back lit control panel = mo mojo = mo money :icon_biggrin:
Regards,
JT
