August 29, 2026, 08:27:24 pm
Hoffman Amps Forum image Author Topic: Traynor Effects loop location  (Read 4334 times)
Offline Mr.Death
« on: October 21, 2022, 03:55:10 pm »
Hello! I'll be installing a passive effects loop into my Traynor YBA-3 and would like to know if the location (red dot) on my schematic is an ideal place to add the loop? I'll just be adding a Boss DD3 in the loop if that matters.
Thanks.
Offline thetragichero
Re: Traynor Effects loop location
« Reply #1 on: October 21, 2022, 03:59:52 pm »
i'd think the master volume pot wiper would be a much better place for it
Offline Mr.Death
« Reply #2 on: October 21, 2022, 04:27:43 pm »
So right before C35? Circle in yellow.
« Last Edit: October 21, 2022, 04:30:10 pm by Mr.Death »
Offline d95err
« Reply #3 on: October 22, 2022, 02:44:09 am »
A passive fx loop does not seem like a good idea in this amp. The signal level at the master volume could be something like 100V peak. In the loop, you’d want something like 1V or less.
Putting a passive loop after the master volume could work in theory, but only if the master is kept very low. I think you could potentially risk damage to whatever you put in the loop if the master is set to anything but really quiet.
I would recommend some type of active loop instead.
Offline Latole
« Reply #4 on: October 22, 2022, 03:10:53 am »
I will not mod a piece or history amp with hole in the chassis.
« Reply #5 on: October 22, 2022, 04:31:49 am »
Your yellow dot is the ideal place for a simple passive loop. Signal level will only be about 2 volts peak.
