September 15, 2026, 11:06:23 pm
Hoffman Amps Forum image Author Topic: help with input stage plate voltage issue  (Read 5015 times)
Offline joesatch
  • save me from myself.
« on: October 22, 2022, 07:22:32 pm »
So i have this part of a schematic not behaving as expected.  With the switch engaged (ground after the 1M), i get 100V plate (pin 6, good.). With the switch disengaged i get 10V at the plate (not good). This channel should be muted with switch engaged but disengaged only getting 10V on the plate.
Online sluckey
Re: help with input stage plate voltage issue
« Reply #1 on: October 22, 2022, 07:33:48 pm »
The plate voltage should not change regardless of the position of the switch, unless... that 1M resistor is really not connected to ground. Or some other wiring error.
Offline joesatch
« Reply #2 on: October 22, 2022, 08:03:15 pm »
it's connected to ground. the interesting thing is in the circuit the 1 meg reads 280 ohm (powered off)
Online sluckey
« Reply #3 on: October 22, 2022, 08:07:15 pm »
It ain't wired like your schematic.
Offline joesatch
« Reply #4 on: October 22, 2022, 08:27:04 pm »
i figured it out. i had the negative on the switch shared with a relay negative (power). when in doubt start disconnecting things i guess.
