September 08, 2026, 11:22:10 am
Hoffman Amps Forum image Author Topic: Bassman 10 speaker recommendations  (Read 8254 times)
« on: October 24, 2022, 11:34:45 am »
Looking for ideas for a Bassman 10 speaker replacement of all 4.   This is a ported front firing enclosure combo cabinet 4 x 10, it has 5 port holes on the front baffle.   Amp to be used for light jazz, blues rock bass and guitar.  Probably going to wire them 8 ohm total..  two 8 ohm speakers in series then in parallel for 8 ohm total  -  unless that isn't a good idea. Thoughts welcome on that too.
Some that came to mind were 25W Weber 12F150s,  maybe 2 of those along with 2 Weber 10" alnicos.  Some Jensen models.
It might come down to what is avaliable.  The speakers should be around 25w.
Let me hear your ideas..   cost not consideration.
« Last Edit: October 24, 2022, 01:31:53 pm by mresistor »
Re: Bassman 10 speaker recommendations
« Reply #1 on: October 25, 2022, 03:28:40 pm »
Never thought about this before but I would consider installing one set of 2 more bass-centric and the other 2 more fendery-centric and then switching on the rear so when you play bass it's one way and vice-versa.
I like mixing speakers anyway, so I actually would actually consider this over 4 of the same.
For the Fendery ones I would look at the Jensen P10R-F Jensen P10R-F 25W 10" Guitar Speaker - StewMac
« Reply #2 on: October 25, 2022, 04:18:17 pm »
Interesting SG   I was thinking of a mix myself.  It never occurred to me to put in bass speakers and guitar speakers for 2  2x10s in the same cabinet.  I don't think that's a great idea unless the cabinet could be devided into two separate enclosures. The non operating speakers would suck the sound wave off of the operating ones in a 4x10 cab. dampen them.
But the mix is interesting and probably a good way to go.   Thanks  :icon_biggrin:
