September 16, 2026, 12:03:28 am
Hoffman Amps Forum image Author Topic: Mullard 6BM8  (Read 4902 times)
Offline rafe
  • I have tube amps
Mullard 6BM8
« on: October 24, 2022, 01:46:18 pm »
I picked up 2 pairs of matched Mullards(ecl82) early 60's if I recall. They have some green corrosion on the pins not too bad what is the safest way to clean them? Also grabbed NOS 12at7's and others I recognized He has a lot left but mostly used oddball (to me) tubes
« Last Edit: October 24, 2022, 04:38:54 pm by rafe »
Rafe
Offline bmccowan
  • Better builder than player
Re: Mullard 6BM8
« Reply #1 on: October 24, 2022, 05:20:28 pm »
I use one of the pin straightener tools and some Deoxit. A few passes in and out of the straightener usually does it. I've seen YouTube vids using a Dremel with wire brush - seems crazy to me. I also keep some 220 grit sandpaper nearby for such things.
I'm curious what you are using them in. I have a Gibson GA-8T and a Little Wing Mini Bassman - both are sweet amps.
Mac
John Prine
Re: Mullard 6BM8
« Reply #2 on: October 24, 2022, 09:14:56 pm »
Typewriter eraser.
Sorry!
Offline rafe
  • I have tube amps
Re: Mullard 6BM8
« Reply #3 on: October 24, 2022, 09:32:43 pm »
"I'm curious what you are using them in."        I have an old Conrad (Japan) stereo amp that uses them. I think my ga-5t
has one also, I would have to look again.
Typewriter eraser.
Sorry!
  :dontknow: All I have is white-out
Rafe
Offline bmccowan
Re: Mullard 6BM8
« Reply #4 on: October 24, 2022, 10:07:54 pm »
typewriter eraser! good idea.
Yes I think the 5T has that tube. I've often thought of building one of those. Like it?
Mac
John Prine
Offline rafe
  • I have tube amps
Re: Mullard 6BM8
« Reply #5 on: October 24, 2022, 11:37:05 pm »
yes I  love the ga5t I started to build one a few years ago and need to finish it. I have and old combo late 50's and it has 2 alnico 10's and i need to mate them into that build.those late 50's to 61 Ga5 s and 5ts  are quite amazing! I have both a 5 and a 5t 1960
Rafe
Offline kde
Re: Mullard 6BM8
« Reply #6 on: October 25, 2022, 06:27:45 am »
I use a Green 3M Scotch Brite heavy duty scourer kitchen pot cleaner pad,
nice & easy slowly carefully drag thru the gap between pins on 9 pin tubes .
Has always worked successfully for me really well.
