August 29, 2026, 08:27:55 pm
Hoffman Amps Forum image Author Topic: St George Massie 1263 Scratchy Sound  (Read 6435 times)
Offline oogabooga23
« on: October 24, 2022, 09:31:43 pm »
Whenever I turn the volume knob on my guitar, there is a scratchy sound coming out of the amp. This only happens in 1 of the 4 inputs. I haven’t tested any leakage, but I am assuming it could be a bad capacitor?
Re: St George Massie 1263 Scratchy Sound
« Reply #1 on: October 25, 2022, 06:26:36 am »
I'd look for a bad connection, either at jack, sketchy solder on the jack, or parts connected to the jack
« Reply #2 on: October 25, 2022, 08:16:24 am »
schematic...
« Reply #3 on: October 25, 2022, 08:35:34 am »
^^ thanks
I'll add C2 to the mix then
« Reply #4 on: October 25, 2022, 08:57:10 am »
Would be helpful to know which input.
Offline oogabooga23
« Reply #5 on: October 25, 2022, 09:12:17 am »
It was on input 2 above the tremolo, should of specified
Offline oogabooga23
« Reply #6 on: October 25, 2022, 09:22:42 am »
There also seems to be a problem with the tremolo circuit not working at all. I saw somewhere that they fixed the problem by replacing the 6CA4 rectifier tube, but I don't see how that would necessarily help. Changing the tremolo tube with a known good one did not help either.
« Reply #7 on: October 25, 2022, 09:38:31 am »
What does that mean?
Look at the schematic I posted. There are 4 inputs labeled TREMOLO, GUITAR, BASS, and ACC. Which one is scratchy?
Offline oogabooga23
« Reply #8 on: October 25, 2022, 10:26:47 am »
It's the one labeled GUITAR, sorry about that
« Reply #9 on: October 25, 2022, 10:48:11 am »
:laugh:
took that to mean the 1st of 4, then the schematic inferred Trem as the 1st of 4
I miss the days of reading error logs and diagnostic results  :icon_biggrin:
« Reply #10 on: October 25, 2022, 12:10:46 pm »
Yeah. We had better communications skills back then and the brain was not cloudy all day!    :l2:
« Reply #11 on: October 25, 2022, 12:13:51 pm »
Are you a tech and have a dmm? If so, plug a guitar cable into the guitar input but don't connect the other end to anything. Now measure dc volts between tip and sleeve of the dangling plug. What have you?
Offline oogabooga23
« Reply #12 on: October 25, 2022, 07:06:29 pm »
I am no tech at all, but I do have a multimeter. I measured 0.9 volts DC in the GUITAR input, 0.5 volts DC in the BASS input, and 0.4 volts DC in the GUITAR/ACC input. For the TREMELO input, I kept getting a reading of 0 volts.
Offline oogabooga23
« Reply #13 on: October 26, 2022, 12:39:24 pm »
It seems that the problem resolved itself after I removed the death capacitor when I was making a negative feedback switch. I don't know why I didn't remove it to begin with, even though I installed a 3-prong, and the ground switch was useless. With that resolved, I can start to figure out how to get the tremolo working, as the tube lights up but it does not make any sound.
