September 14, 2026, 06:09:53 pm
Hoffman Amps Forum image Author Topic: My first 5e3 build  (Read 26210 times)
Offline Ledvedder
Re: My first 5e3 build
« Reply #50 on: October 30, 2022, 09:21:55 pm »
how about this for the fixed bias: https://www.tubesandmore.com/products/trimmer-piher-single-turn-side-adjust-vertical-pcb-mount
25uf should be fine if they're the appropriate voltage rating. i've seen 8uf in big amps, not a puny deluxe
I grabbed these from Amazon, uxcell 8Pcs 50K Ohm Variable Resistors Single Turn Rotary Carbon Film Taper Potentiometer with Knobs https://a.co/d/02y29LC.
Since the 50uF is a smoothing cap, could I perhaps go larger? I have some 100uF up to 330uF caps on hand.
« Last Edit: October 30, 2022, 09:24:02 pm by Ledvedder »
Offline Ledvedder
« Reply #51 on: October 31, 2022, 04:19:13 pm »
Fitting the impedance selector switch. It's tight, but it should work.
Offline Ledvedder
« Reply #52 on: October 31, 2022, 06:29:22 pm »
Switch wiring done.
Offline Ledvedder
« Reply #53 on: November 02, 2022, 07:40:51 pm »
I like how this bias pot sits on the board.
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #54 on: November 03, 2022, 10:03:48 am »
Isn't there an advantage to having a 25 turn pot for bias adjustment?
Can you still get the precision that you need with a one turn pot?
Offline acheld
« Reply #55 on: November 03, 2022, 10:13:46 am »
No, and yes.
Don't get me wrong, I love Bourns' trimmers, but these are guitar amps we're talkin' about and you don't 3 decimal point precision.
Offline Ledvedder
« Reply #56 on: November 03, 2022, 10:14:18 am »
I don't see why not. I have a few other amps that use a standard pot for bias adjustment.
Offline Ledvedder
« Reply #57 on: November 03, 2022, 11:50:05 am »
Is it recommended to wire the filaments before or after the board installation and wiring? In all my other builds, which were much larger chassis, I wired the filaments first.
Offline acheld
« Reply #58 on: November 03, 2022, 08:23:10 pm »
Like everything else in this world, it depends.   If I'm putting heater wires on the floor, I'll wire them sooner.  If overhead, they are last.
Builders choice, they call it.
Seriously, you have to think about "layers" of components, like planning in 3D, which is exactly what you're doing.
Offline Ledvedder
« Reply #59 on: November 04, 2022, 08:53:26 pm »
I started wiring the 50k pot and the switch for the switchable bias mod. This one's pretty tricky to find room.
Offline bmccowan
  • Better builder than player
« Reply #60 on: November 04, 2022, 09:07:06 pm »
My old fingers and eyes find heater wiring the toughest part of wiring an amp. So I do them first so that other stuff is not in the way, and so I can relax and have a beer. But I have also gradually moved away from flying them overhead.
Mac
John Prine
Offline Ledvedder
« Reply #61 on: November 04, 2022, 09:37:34 pm »
A wee bit of tube socket wiring.
Offline bmccowan
« Reply #62 on: November 04, 2022, 09:53:09 pm »
I'm curious - it looks like you are going straight in and soldering? I know that works, but I do not trust that and always make a bend to make a mechanical connection. I do not wrap the tube socket lugs - just create some resistance with a +/- 90 degree bend.
Mac
John Prine
Offline Ledvedder
« Reply #63 on: November 04, 2022, 11:20:16 pm »
I've always done it this way. This is the 5th amp I've built, and I've never had any issues with the joints.
« Reply #64 on: November 05, 2022, 12:23:07 am »
Over time you very well might start to have problems. We've seen it happen more than a few times. Solder is not glue.
You can build your amp any way you like, but, he's trying to give you some insight from experience. Many of us here do agree with him.
Offline Ledvedder
« Reply #65 on: November 05, 2022, 12:30:04 am »
Yes, I understand that. I hope my response didn't come across incorrectly.
« Reply #66 on: November 05, 2022, 08:35:39 am »
Your fine, no harm, no foul.    :icon_biggrin:
Your builds going to be very nice, carry on.  :icon_biggrin:
Offline JPK
« Reply #67 on: November 05, 2022, 09:11:24 am »
It's amazing what I got away with on my first two builds. I had no issues at all. Then the third, and most recent one, I had some issues. Zero wiring errors but some bad solder joints. I ended up giving it to an amp tech friend of mine. He sorted it out in short order. I'll be providing the report here on my build thread (he didn't have time to give me all the details, soon). I'll learn from his report for sure. I wanted to get this all done before I started my 5E3 project. Probably getting the Boot hill one as well. Do you think those upgrades for filter and coupling caps are worth it? Adds only about $25.
« Last Edit: November 05, 2022, 09:13:48 am by JPK »
I love tubes
Offline Ledvedder
« Reply #68 on: November 05, 2022, 09:18:54 am »
Good to hear you're getting things sorted out. I'm not sure if the cap upgrade is worth it, but I figured what the heck. I'll have no way of comparing them. But I trust other builders' opino, since they have much more experience than me.
Offline JPK
« Reply #69 on: November 05, 2022, 10:01:58 am »
If you got other builders opinion that's good enough for me. I didn't see mention of that in this thread, or I missed it. The only problem I had with my last build was crackling and buzzing at like 3/4 volume on the clean channel. The high gain channel was perfect. Honestly I probably wouldn't play it that loud on clean anyway but I like things working right. I'm ok making mistakes as long as I learn something. With this hobby the learning never stops.
I love tubes
Offline Ledvedder
« Reply #70 on: November 05, 2022, 10:19:16 am »
And that's exactly what I love about this hobby. I enjoy it, and I've learned a ton. Also, at the end of the day, I have some great amps. that I'm proud to say I made.
« Reply #71 on: November 05, 2022, 12:31:25 pm »
I like these!
Chassis mount that don't take up much space with a locking shaft.
--Pete
Offline Ledvedder
« Reply #72 on: November 05, 2022, 02:16:40 pm »
Things are getting tight!
Offline Ledvedder
« Reply #73 on: November 06, 2022, 09:40:39 am »
I've been going back and forth, trying to decide which mod switched I'd put in place of the standby switch. NFB or bias switch. Then I thought, why not do the pre-PI master volume there? Replacing the 1M resistor with a 1M pot. Then, I'll just put both of the other switches in the chassis.
Offline Ledvedder
« Reply #74 on: November 06, 2022, 01:20:31 pm »
NFB switch and bias switch mounted. Bias switch is wired up.
Offline Ledvedder
« Reply #75 on: November 06, 2022, 04:50:27 pm »
I think I'm fairly close to complete. Moving on to filament wiring. My favorite part 👎
Offline Ledvedder
« Reply #76 on: November 06, 2022, 05:44:21 pm »
Filament wiring completed!
Offline Ledvedder
« Reply #77 on: November 06, 2022, 08:27:03 pm »
Ready for first power up! 🤞
Offline bmccowan
« Reply #78 on: November 06, 2022, 09:06:10 pm »
Congrats on getting to this stage. Always a nerve racking moment when you slowly turn up that variac.
BTW - just catching up here. I took no offence on the soldering technique response
And the reality is I think it depends on the life the amp will live: rattling around in the back of an Econoline van, or residing in the home.
Mac
John Prine
Offline Ledvedder
« Reply #79 on: November 06, 2022, 09:40:46 pm »
No worries. No offense taken.
Offline Ledvedder
« Reply #80 on: November 06, 2022, 09:49:45 pm »
Deleted.
« Last Edit: November 06, 2022, 10:42:49 pm by Ledvedder »
