September 15, 2026, 10:42:41 am
Hoffman Amps Forum image Author Topic: 6BM8 triode plate resistor Q  (Read 6138 times)
« on: October 30, 2022, 09:10:56 am »
I have done a series resistors approach before to attempt to lower gain and increase a cleaner/clearer tone.  And it worked!
My understanding is the triode section of the 6BM8 is more like a 12AX7 or a 12AT7?   I'd like it to be more like a 12AY7,12AV7 or 12AU7 with less gain.  I want to use the 6BM8 triode in the LTPI and NOT substitute a 12A_7 version.
I'm trying to think thru an amp design prior to building it after the first of the 2023 yr (meaning that  I don't have the amp here to experiment with currently).
Would this approach work and also give a cleaner tone in the LTPI in lowering gain?
With respect,  Tubenit
« Last Edit: October 30, 2022, 09:13:37 am by tubenit »
Re: 6BM8 triode plate resistor Q
« Reply #1 on: October 30, 2022, 09:41:49 am »
Ciao Tubenit
That 220pf capacitor is confusing me
why use it ? To bypass some frequencies and prevent theyr attenuation .... but why only one cap and don't use one by side ??
However using a split load resistor on a LTPI may be the solution of your ... "problem"
May be the read of this page can be of some help to find an answer to your question
http://www.valvewizard.co.uk/acltp.html
« Last Edit: October 30, 2022, 10:03:03 am by kagliostro »
« Reply #2 on: October 30, 2022, 11:57:51 am »
Using split plate load resistors doesn't actually change the gain of the tube. The resistors simply form a voltage divider so you will send less signal to the next stage.
« Reply #3 on: October 30, 2022, 12:11:05 pm »
That 220pf capacitor is confusing me          why use it
https://el34world.com/Forum/index.php?topic=12723.msg153636#msg153636
Sluckey,   thanks for the response!  always helpful
with respect, Tubenit
« Reply #4 on: October 30, 2022, 12:14:57 pm »
I didn't read all the link, but the question Is why only One ?
« Reply #5 on: October 30, 2022, 12:24:47 pm »
Using the cap as shown is NOT a smoothing cap. It actually boosts the high freq signal by bypassing around the resistor connected to the plate. Putting that cap across the other resistor would be a smoothing cap because it would shunt some high freq signal to B+ which is signal ground.
« Reply #6 on: October 30, 2022, 01:15:48 pm »
Thanks Steve
That has a sense, now all is fine
« Reply #7 on: October 30, 2022, 08:02:38 pm »
My understanding is the triode section of the 6BM8 is more like a ... 12AT7?
Yeah but with A = 70, gm = 2200uS (half the transconductance of an AT, with a smidge more gain)
« Reply #8 on: October 31, 2022, 12:03:05 pm »
....half the transconductance of an AT...
The book-specs on 12AT7 are taken at very high current (10mA) for RF applications. We don't run them that way in audio (even as reverb driver). Gm goes down with plate current. For quick estimate, roughly as square-root. Some junior engineer was tasked to plot Gm in a range of conditions, see page 4:
https://frank.pocnet.net/sheets/093/1/12AT7.pdf
