September 14, 2026, 05:36:41 am
Hoffman Amps Forum image Author Topic: No sound after changing resistor and rect diodes (rookie alert)  (Read 6432 times)
Offline fkitch
« on: November 06, 2022, 11:33:15 am »
Rookie, it’s my first (repair) project, apologies for missing the obvious, something I am totally sure I’m doing. :help:
 It’s a Italian Sound Big 25 RT amp from the 70s you guys already helped me with
Ok, the 270k resistor in the pic burnt, not sure why honestly, while I was messing around with a different tank  trying to figure out why the reverb is not working (trem works ok BTW).
One of the diodes also was damaged (melted) by the resistor itself.
I changed both diodes to 1N5408 and put a new 270k resistor like the one in the pic (metal oxide)
Result, 18V after the 270k resistor (I read 330v from the diodes) and no sound.
Any tips on next diagnose / potential fix would be appreciated!
Original pdf schematic:
https://www.freestompboxes.org/viewtopic.php?t=30169
Thank you!!
Fernando
Re: No sound after changing resistor and rect diodes (rookie alert)
« Reply #1 on: November 06, 2022, 11:48:23 am »
That resistor can't possibly be 270K. Must be an error on the schematic. 270Ω or 1KΩ is more likely. What resistance does your burnt resistor read?
Offline fkitch
« Reply #2 on: November 06, 2022, 12:16:42 pm »
Thanks Sluckey
It was so calcinated I just threw it away
But I do have a good picture of it, I attach it here
« Reply #3 on: November 06, 2022, 12:22:43 pm »
I suggest using a 270Ω 10W resistor.
Offline fkitch
« Reply #4 on: November 26, 2022, 12:00:56 pm »
Ok, finally found some time to go on
I changed the resistor to a 270 ohm 10W and I have sound again!! Thanks Sluckey!
Bad news, now there’s a fast ticking noise (heard through the speakers) with random static noise too), even without a guitar plugged in.
It takes a few seconds for the ticking to appear after switching on the amp and its volume and frequency are not affected by any of the amp controls.
It just disappears when I remove both v1 and v2 (clean and reverb channel 1st tubes)
After the resistor burnt I had to change the rect. diodes as well and had to be ‘creative’ in terms of wiring positioning (one diode crosses above the other) , not sure if that’s the issue but moving them slightly did not make a difference
Chopsticking didn’t show any potential faulty components or wiring
The new resistor is of those white cemented type large ones, vertical leads, not axial
« Reply #5 on: November 26, 2022, 12:17:06 pm »
There are 11 triodes being supplied by one B+ filter cap. I'm surprised it doesn't play "The Star Spangled Banner" all by itself.   :l2:
Offline fkitch
« Reply #6 on: November 26, 2022, 12:50:49 pm »
Give me time, I’ll make it play it, Hendrix style, and of course end up in flames to end the show :icon_biggrin: :icon_biggrin:
Ok , I just realised that, thanks to my creative repositioning of things, some components now cross over the trem intensity pot wires…
I’ll start there
Offline Williamblake
« Reply #7 on: November 26, 2022, 01:53:25 pm »
Just out of curiosity, what type of reverb tank is in that amp? What resistance do you measure across the tanks input? (There maybe high voltage present, you would have to drain the filter caps / B+ caps / HT caps to do that).
Offline Esquirefreak
« Reply #8 on: November 26, 2022, 03:16:26 pm »
I serviced an old FBT amp a couple of years ago. They were made in Italy, but clearly inspired by Marshall amps. All Mullard, ISKRA and Philips components. Looking a lot like the trem channel of a Marshall 1974
On the schematic, however, all cap values was marked as "K" rather than Farad/F. Like 22k rather than 22nF.
I suspect that some details were lost in translation when "borrowing" circuits.
/Max
« Reply #9 on: November 26, 2022, 05:13:37 pm »
Some days, "all caps are in pFd".
22 K pFd is 22nF.
Offline fkitch
« Reply #10 on: November 27, 2022, 04:59:22 am »
Ticking solved! It was a bad solder work on one of the new diodes. :BangHead:
 About the filter caps, there’s another 32uf one but it’s not in the schematic…
Thanks for the HV reminder! back to the reverb not working:
When activated by the footswitch if I turn the reverb level up all it does is add white-ish noise, the higher the reverb level the higher the noise.
Already tried different tubes, and already changed the electrolytic caps , no change in behaviour. Also reflowed solder joints
The tank itself (picture attached)
Small, around 18x8cm. No brand just says ‘PAT. NO. 2982819’
Resistance at the side that has a resistor:9.96 kOhm
Resistance at the side without resistor: 290 Ohm
Resistance across both positive terminals: 10.24 kOhm
/Max
I thought it was based on a Fender Super Reverb , but no idea honestly. Changing the clean channel to be more Marshall sounding could be an option for a next phase!
22 K pFd is 22nF.
Correct!
Thanks all for your inputs!
