September 14, 2026, 12:18:41 pm
Hoffman Amps Forum image Author Topic: New 5e3 build voltage check  (Read 6418 times)
Offline Ledvedder
« on: November 07, 2022, 02:09:47 pm »
I'm just wondering if these voltages are acceptable on my new 5e3 build? B+2 seems a bit high at 333V, which is also affecting pin 4 on the power tubes. Also, the v1 voltages seem a bit low. I've noted my voltages in pen on the attached image.
Re: New 5e3 build voltage check
« Reply #1 on: November 07, 2022, 02:27:12 pm »
Look fine to me.
Offline bmccowan
  • Better builder than player
« Reply #2 on: November 07, 2022, 02:48:59 pm »
When I get that close to spec, I am extremely happy and have a beer. Since its election season... they are all within the margin of error. Play it yet?
Mac
John Prine
Offline Ledvedder
« Reply #3 on: November 07, 2022, 07:24:05 pm »
sounds ok. Not great yet. I think I'm having an issue. The NFB switch works in only position 1. In the center position, the sound just fizzles out. In the 3rd position, I get sound, but as soon as I whack a note, it fizzles out.
I'm, also having a hard time deciphering which side of the bias switch is stock 5e3, and which is fixed bias.
« Reply #4 on: November 07, 2022, 07:54:13 pm »
In the stock position there will be zero vdc on pin 5 of the output tubes and some positive vdc on pin 8.
In fixed bias there will be some negative voltage on pin 5 and zero volts on pin 8.
Offline Ledvedder
« Reply #5 on: November 07, 2022, 08:32:40 pm »
This is with the output tubes installed?
Offline thetragichero
« Reply #6 on: November 07, 2022, 08:40:13 pm »
fixed bias with or without tubes installed. cathode bias there won't be negative voltage on the grid but there also won't be positive voltage on the cathode without tubes installed
Offline Ledvedder
« Reply #7 on: November 07, 2022, 09:24:10 pm »
This helped me determine which switch position was fixed vs cathode. Thanks!
Now to figure out what's going on with the NFB switch.
Offline JPK
« Reply #8 on: November 07, 2022, 10:24:46 pm »
You may need to flip the OT primary leads for the NF. With my 18 watt AX84 October I had to do that. It will make a nasty noise if it's wrong. I had a switch to turn NF on or off. I haven't looked at what your three way does.
 Also had to increase tail resistor for fixed bias. It was a little too hot even with the pots dialed all the way down (I had one for each tube).
« Last Edit: November 07, 2022, 11:01:49 pm by JPK »
I love tubes
Offline Ledvedder
« Reply #9 on: November 08, 2022, 05:44:35 am »
My 3 way switch is doing stock mode/no v2a bypass cap/56k NFB with no bypass cap. I've attached the diagram.
I haven't gotten to the fixed bias adjustment yet. Did you just use the instructions here, https://robrobinette.com/Tube_Bias_Calculator.htm?
Offline JPK
« Reply #10 on: November 08, 2022, 11:17:55 am »
I can't remember if I used that since I built the amp 10 years ago. I ended up using 24ma for my 6V6GT's. I used 1 ohm in line resistors and had test ports on mine which were really handy. Whatever you measure in mv is the ma bias current.
PS: I ordered my 5E3 kit from Boothill today. My build is going to be super stretched out time-wise. I like taking my time especially since I'm retired. Hopefully it's not done before xmas.  :sleepy2:
« Last Edit: November 08, 2022, 11:31:23 am by JPK »
I love tubes
