September 14, 2026, 02:26:44 pm
Hoffman Amps Forum image Author Topic: Potentiometer Wattage question  (Read 5531 times)
Offline Soulchief
« on: November 08, 2022, 02:02:50 pm »
Hello all,
Trying to fit a ‘10K-A Mid Pot’ into a DIY Fender Champ with semi tight spacing and not enough room to fit a standard 24mm pot.
Looking at 16mm Alpha Pots, with a ‘Wattage Rating of .06W’, is that too low for Tone Pots on Fender Amps?
Linear 16mm Alphas are .125W. Not sure why Audio/Log are only .06W...
And of course the larger standard pots are .25W.
Would the .06W Rating be safe in the case of a Mid Pot?
Thanks for your help
Offline d95err
Re: Potentiometer Wattage question
« Reply #1 on: November 09, 2022, 01:22:07 am »
16mm Alphas are fine for any normal use in tube amps. It’s just signal voltages with very little current. You’ll find 16mm pots in most modern amps.
Offline Latole
« Reply #2 on: November 09, 2022, 03:48:50 am »
Any pot will do the job.
« Reply #3 on: November 09, 2022, 05:01:03 am »
The only typical valve amp application where a 60mW pot would struggle is the 50k trem intensity control of a black or silver panel 2 channel Fender.
Based on overdriving it heavily like Ted Nugent, which might result in prolonged periods of a roughly 60Vrms signal across it.
Offline Soulchief
« Reply #4 on: November 09, 2022, 06:24:31 am »
Thanks for the help and with all your answers agreeing it will be ok I will throw one in.
Curious for knowledge, what would be a sign that a pot is not keeping up or struggling? Just stop working?
« Reply #5 on: November 09, 2022, 06:44:59 am »
I suppose there might be somewhere along the track it burns out.
To speculate in detail how that would play out, you need to specify whether the pot is wired as a pot or a variable resistor type of midrange control.
Whichever, there would probably be a setting that lifted the tone stack, big increase in signal level, tone controls disabled.
Offline Soulchief
« Reply #6 on: November 09, 2022, 10:32:57 am »
Ok yes that makes sense.
In this case I guess this will be set up as a Variable Resistor Mid Pot as in AB763’s:
Bass Pot Lug 1 > New Mid Pot Lug 2 > .047 Tone Cap  //  Ground Mid Pot Lug 1
This is where the .06W Mid Pot is in question - which answers seems to agree OK..
« Reply #7 on: November 11, 2022, 02:23:42 am »
… with a ‘Wattage Rating of .06W’, is that too low for Tone Pots on Fender Amps?
Figure out the actual* application I.e.;
Voltage drop across the pot divided by the resistance of the pot = current through the pot. Current through the pot times voltage across the pot = power dissipated by the pot. If this sums to 0.03W or less, a 0.06W rated pot would be fine.
* a mid pot in a Twin Reverb as no DC across it, and in terms of signal voltage it’s only a handful of mVac. So you’ll be fine
« Last Edit: November 11, 2022, 02:32:34 am by tubeswell »
Offline Soulchief
« Reply #8 on: November 11, 2022, 01:10:19 pm »
Thank you to all thanks helped with reply..
Ordered up a Pot this morning!
