September 15, 2026, 07:29:26 am
Hoffman Amps Forum image Author Topic: Presence contol placement within NFB loop  (Read 10001 times)
Offline 12AX7
« on: November 13, 2022, 09:49:40 am »
I was reading robrobinette's site and noticed he mentions that the presence works differently (seems to suggest "better")  when on the OT side of the NFB resistor. Anyone know what sort of difference it makes?
Offline acheld
Re: Presence contol placement within NFB loop
« Reply #1 on: November 13, 2022, 10:53:58 am »
Just to be clear, we're talking about this page, right?  https://robrobinette.com/Voicing_an_Amp.htm#Presence_Control
His explanation doesn't make sense to me -- if you look at the schematic he is referencing, the presence control pot does not take input directly from the OT.   However, the resonance pot does, and maybe that is what he is really talking about -- putting the resonance circuit before the NFB resister.
I'm not sure how much difference it makes putting the resonance control before the NFB resistor, but this is usually where it is placed in several modern circuits that I've reviewed recently.
Offline 12AX7
« Reply #2 on: November 13, 2022, 11:00:56 am »
Yeah, he says "Generic Presence Control circuit. The Presence cap sends high frequencies to ground. The Presence pot varies how much high frequency signal is sent to ground. Removing high frequencies from the negative feedback circuit boost highs at the speaker. Placing the cap on the output transformer side of the NFB resistor will give best control authority."
I tried it and the amp lost about 90% of it's volume. I checked over and over to make sure i did it right. So i must be doing something wrong but for the life of me i can't figure it out.
« Reply #3 on: November 13, 2022, 11:04:20 am »
What the heck is "control authority"?
I see those beers have worn off already.   :laugh:
Offline 12AX7
« Reply #4 on: November 13, 2022, 11:20:42 am »
They have indeed, and as to control authority who knows. I just thought this is something new i never tried so i'm always up for potential improvements. Either i made a mistake for HIS beers hadn't worn off when he wrote that. :icon_biggrin:
« Reply #5 on: November 13, 2022, 11:28:47 am »
That was a Generic Presence Control circuit. You probably didn't have a proper generic amp to do the test.  :wink:
« Reply #6 on: November 13, 2022, 11:47:50 am »
It’s disappointing that Rob resorts to this type of nonsensical hyperbolics, doesn’t even bother explaining how to arrange a presence control with its cap like that  :dontknow:
If you can’t baffle them with science, blind them with BS.
It’s
« Reply #7 on: November 13, 2022, 01:33:42 pm »
 :laugh:
I've always used it "If you can't charm them with wisdom, baffle them with B.S."
Offline bmccowan
  • Better builder than player
« Reply #8 on: November 13, 2022, 02:06:51 pm »
And if you can't baffle them with B.S. - well, you just ain't tryin' hard enough.
Especially since that is Gerald Weber's job.
« Last Edit: November 13, 2022, 02:14:47 pm by bmccowan »
Mac
John Prine
« Reply #9 on: November 13, 2022, 06:02:53 pm »
It’s disappointing that Rob resorts to this type of nonsensical hyperbolics,... ....blind them with BS.
It also says "harrier", which is a jump-jet.
Instead of deserving vitriol and personal slander, maybe it just needs another editing pass? It's a MASSIVE page with tons of info.
« Reply #10 on: November 13, 2022, 06:46:26 pm »
Apologies, I didn’t intend such a strong effect.
Offline dwinstonwood
« Reply #11 on: November 13, 2022, 09:13:54 pm »
...maybe it just needs another editing pass?
Or, two. I'm sure that an "NFB loop witch" is not some sort of electrical gremlin, but a typo.
« Reply #12 on: November 13, 2022, 09:27:55 pm »
an "NFB loop witch" ... .
which ole witch
« Reply #13 on: November 14, 2022, 08:35:46 am »
… I tried it and the amp lost about 90% of it's volume. I checked over and over to make sure i did it right. So i must be doing something wrong but for the life of me i can't figure it out.
I can’t think how to implement a presence control with its cap on the output transformer side of the NFB resistor  :dontknow:
How did you do it?
Offline 12AX7
« Reply #14 on: November 14, 2022, 09:19:12 am »
How did you do it?
just by swapping it to the other side of the nfb resistor
« Reply #15 on: November 14, 2022, 10:01:59 am »
Ah, there's a helpful diagram by that text  :smiley:
I can't see how that's going to even function as an active control?
Seems to be a passive tone control across the amp's output, with minimum treble at lowest control resistance, contrary to the 'turn up for more presence' note?
« Last Edit: November 14, 2022, 10:29:53 am by pdf64 »
Offline acheld
« Reply #16 on: November 14, 2022, 10:07:41 am »
Well, Robbie is a pilot, after all, and in that world it simply means that when you give a command via the control stick, the airplane responds accordingly -- you would think that is a given, but there are situations when it is not so.
Taking the analogy to its logical conclusion, I'd assume that he means that when you turn the knob, you can hear the difference.
All that aside, there are plenty of good suggestions on his website.  I regard them as a smorgasbord . . . to be sampled, but not necessarily copied.    This is one that needs some work IMO.
« Reply #17 on: November 14, 2022, 10:21:45 am »
I get the military image of a Sergeant shouting "GIVE ME MORE PRESENCE!" and the pot responding "SERGEANT, SIR YES SIR".  :laugh:
« Reply #18 on: November 14, 2022, 10:32:20 am »
Rob's site seems to be one of the first places new builders like me come across. I agree there's lots of good info there that's explained in a no-math format with plenty of layout illustrations. Smorgasbord is a good description... take what you want, and leave the rest. But, I was trained to be a hyper-critical text editor.  :icon_biggrin:
« Reply #19 on: November 14, 2022, 10:46:12 am »
SIR YES SIR
they did a great job in bootcamp of drilling that permanently into the brain...then I encountered my 1st Female officer
after 100 pushups on the spot, I was sent to PT (physical training) where you ran until you puked, I refused to puke but after 4hrs I did manage to pass out  :laugh:
« Reply #20 on: November 14, 2022, 11:08:49 am »
