September 15, 2026, 12:40:53 pm
Hoffman Amps Forum image Author Topic: Marshall 9005 bias supply?  (Read 9768 times)
Offline Bubbastain
« on: November 14, 2022, 11:39:26 am »
Been a while since I've been here but you guys were super helpful before. I picked up a Marshall 9005 power amp. Channel A works fine. Channel B had a pretty good hum when I took it off standby and then the two power tubes started to red plate. I hooked up a bias probe to each tube and turned the trim pot all the way to the cold side. Still it started to climb too high. Popped in a old but still good pair of el34's and again it started to climb too high. I shut it down once it started climbing past 25.
So what should I change out. I can safely work on an amp and solder, but my skill peaks at paint by numbers. If I'm told what to change I can do that. I will post a gut shot as soon as I get home. Any help would be appreciated.
« Last Edit: November 14, 2022, 12:39:23 pm by Bubbastain »
Re: Marshall 9005 bias supply?
« Reply #1 on: November 14, 2022, 11:50:59 am »
Before changing anything, pull the EL34s and measure voltage on pin 5 of each EL34 socket. Turn bias pot from one end to the other. What is the maximum and minimum voltage reading for each tube?
Offline Bubbastain
« Reply #2 on: November 14, 2022, 12:36:22 pm »
I measured 483v on pin 5 on all power tubes on both channel A (good side) and channel B. Turning the bias trim pot (PR2) from one end to the other made no difference.
« Reply #3 on: November 14, 2022, 12:38:56 pm »
Impossible! Please redo. Count pins carefully.
Offline Bubbastain
« Reply #4 on: November 14, 2022, 12:56:14 pm »
Okay. Wrong pin. Pin 5 is 0. Turning the trim pot made no difference. On channel A adjusting the trim pot brought it from 28 to 38.
Offline thetragichero
« Reply #5 on: November 14, 2022, 05:08:42 pm »
okay so you're not getting bias voltage on the output tube grids. makes sense why the tubes are redplating
here's a schematic i've found:
time to work backwards. the phase inverter is confusing me
« Reply #6 on: November 14, 2022, 05:29:59 pm »
How much voltage do you measure at the negative lead of C13?
How much voltage do you measure at the negative lead of C8?
Offline Bubbastain
« Reply #7 on: November 14, 2022, 05:54:58 pm »
0v on C8 and C13 in standby or out with no power tubes installed.
On channel A I get 54 on C13 and 45 on C8 in play mode and 72 on C13 and 66 on C8 in standby
« Reply #8 on: November 14, 2022, 06:04:35 pm »
Measure resistance across C13 leads. What have you?
Offline Bubbastain
« Reply #9 on: November 14, 2022, 06:45:50 pm »
Cheap DMM set to ohms 200k it's goes to 84. Amp completely off right?
« Reply #10 on: November 14, 2022, 07:31:25 pm »
Does your meter have a diode check function? If so, unsolder one end of D1 and check it.
Offline Bubbastain
« Reply #11 on: November 14, 2022, 08:43:30 pm »
I measured 593 on D1.
« Reply #12 on: November 14, 2022, 11:55:08 pm »
Volts? Ohms? Rods?
Swap the leads. Now what?
Offline Bubbastain
« Reply #13 on: November 15, 2022, 12:22:04 am »
Volts? Ohms? Rods?
Not sure. I unsoldered one leg, set my mm to the diode test setting and put the negative probe on the side with the silver band and the positive probe on the other end and 593 came up. If I reversed the probes no number showed up.
« Last Edit: November 15, 2022, 12:29:12 am by Bubbastain »
« Reply #14 on: November 15, 2022, 06:37:45 am »
That means the diode is probably good. Was there a decimal point in front of the 593, IOW, was it really .593?
« Reply #15 on: November 15, 2022, 07:13:47 am »
Verify you have several hundred AC VOLTS between the white and blue wires. (One probe on white wire, other probe on blue wire.)
If voltage is OK then problem is in the schematic snip. Most like suspects are C16, D1 (already checked), and C13.
You have two identical circuits. Compare checks between the two. Should be a fairly simple fix.
Offline Bubbastain
« Reply #16 on: November 15, 2022, 11:32:09 am »
I measured 334 vac on the white & blue wires. Same on channel A.
So should I go ahead and order and swap out C16 and C13? Or is there anything else I should check? What else should I replace while I'm at it?
Thanks for the help so far.
« Reply #17 on: November 15, 2022, 11:40:00 am »
just for prudence's sake;
with power off and no PA tube installed, ohm the 4 resistors connected to the 2 power tubes
the schematic shows 2 10ohm and 2 2k ohm
« Reply #18 on: November 15, 2022, 03:18:46 pm »
Replace C8 and D1 while you're at it. Please note... C16 is a special Class X cap. Replace only with another 47nF Class X cap.
