September 17, 2026, 12:51:45 am
Hoffman Amps Forum image Author Topic: 5e8 preamp question.  (Read 6101 times)
Offline johngovan
« on: November 17, 2022, 05:59:29 pm »
I want to omit the extra tubes or input channels and make it just one input channel instead of four. My question is, is the 270k resistor that is highlighted in red needs to go to ground or should I also omit that one?
Re: 5e8 preamp question.
« Reply #1 on: November 17, 2022, 06:39:33 pm »
Omit.
Offline johngovan
« Reply #2 on: November 17, 2022, 06:46:08 pm »
Thank you so much Sluckey. I need to finalize the layout. It helps a lot.
« Reply #3 on: November 17, 2022, 06:55:18 pm »
I would also consider removing the other 270K mixing resistor and that extra 100K mixing resistor.
Offline johngovan
« Reply #4 on: November 17, 2022, 09:31:55 pm »
These resistors? I'm i correct?
« Reply #5 on: November 17, 2022, 09:42:42 pm »
Yes. Pot wiper connects directly to next tube grid.
Offline johngovan
« Reply #6 on: November 17, 2022, 09:46:30 pm »
Thank you so much. I'm really excited to make a low wattage 5e8.
