July 29, 2026, 09:48:28 am
Hoffman Amps Forum image Author Topic: Comparing bias trem circuits  (Read 4776 times)
Offline Esquirefreak
« on: November 18, 2022, 08:11:45 am »
About to start sketching a board layout for a single channel build based around the bright channel of my '63 6G9-B but with some beefier transformers (Hammond 290EEX and Bassman OT).
I was comparing schematics on the bigger Fender amps using bias trem, especially 6G9-B and 6G16. They look alot similar - LFO+CF. The main differences I can see is an additional 20nF cap and higher voltages on the latter.
If I run into trouble with thumping and a diode across the INT pot doesn't fix it - I'll try and move the trem to the second gain stage K.
× Is one trem circuit superior compared to the other?
× Is the 20nF cap in the 6G16 schematic functioning as smoothing cap? Like the 50nF cap on the 6G9-B intensity pot? If not, what's its purpose?
Have a nice weekend, y'all.
/Max
Re: Comparing bias trem circuits
« Reply #1 on: November 18, 2022, 08:13:02 am »
6G16
« Reply #2 on: November 18, 2022, 09:09:12 am »
6G9b Tremolux https://el34world.com/charts/Schematics/files/Fender/Fender_tremolux_6g9b_schem.pdf
6G16 Vibroverb https://el34world.com/charts/Schematics/files/Fender/Fender_tremolux_6g9b_schem.pdf
I think the caps mentioned may be rolling harmonics off the modulation waveform, in an effort to make it more sinusoidal.
I keep meaning to experiment with the trem arrangement of the
5E9a Tremolux https://el34world.com/charts/Schematics/files/Fender/Fender_tremolux_6g9b_schem.pdf
As that might have a bit less thump, due to the coupling caps between phase splitter and output valves rolling it off.
Online sluckey
« Reply #3 on: November 18, 2022, 09:25:21 am »
I would not waste time on bias modulated tremolo for 6L6s (or bigger) tubes. You may get satisfactory results after tinkering a bit and/or compromising your optimum bias setting. As the tubes age, you'll probably find yourself tinkering again and when you change tubes you can just start all over again.
I think this is the reason Fender ditched this circuit in favor of the more reliable roach trem.
« Reply #4 on: November 18, 2022, 11:08:01 am »
Fair point. It might be that my Tremolux's trem sounds/works so great is due to the low voltages and cool bias.
Maybe I'll reconsider and move the trem insertion point to a preamp tube K - Vibrochamp style.
If I had any 7 pin sockets I would use a 6AV6 and your TON instead, but I only have noval sockets on hand. Don't wanna leave half a 12AX7 unused.
Although maybe it would be cool to add a 3rd (possibly parallell gainstage) prior to the PI.
Thanks for chiming in.
/Max
« Reply #5 on: November 18, 2022, 03:22:18 pm »
This works (and still works stunningly after 10 years - same tubes)
