September 08, 2026, 03:50:15 pm
Hoffman Amps Forum image Author Topic: How to make my amp see 8 ohms as 4 ohms   &nb  (Read 4335 times)
Offline Geezer
« on: June 18, 2005, 05:48:42 am »
        > How to make my amp see 8 ohms as 4 ohms
<< Prev Topic | Next Topic >>
Author  Comment
sheepdip
(3/26/04 6:45 pm)
 I have a 2245H JBL that is going to be part of my bass spkr system. At the present time I am going to have it in a single enclosure seperate from the other two 15in speakers. How can I make my amp see this speaker as a 4 ohm load from the crossover instead of the 8 ohm speaker it is?
Tiny Daddy
I will work on all amps
(3/26/04 6:53 pm)
  Re: How to make my amp see 8 ohms as 4 ohms
 Can you connect it to a 16-ohms tap?
sheepdip
(3/26/04 8:29 pm)
  8 ohms as 4 ohms
 Unfortunatly no, I have a 2 ohm and 4 ohm tap
Lucid Alice
Senior tube assistant
(3/28/04 1:43 pm)
  Re: 8 ohms as 4 ohms
 I am assuming the 2x15 is wired in parallel for 4 ohms. If you wire the JBL in parallel with this cab you will get 2.66 ohms. That is close enough to the 2 ohm output isn't it?
sheepdip
(3/29/04 1:55 pm)
  RE: 8 ohms as 4 ohms
 JBL says.......Don't worry about the impedence difference. Tube amps are much more forgiving at clipping levels than transistors and the slight loss is going to be negligable. Also, to get 3 db more I would have to double the PO and at 300+ watts I don't think I am going to look for a 600watt out amp. Just be mindful of the impedence. I don't really want to run the amp at 2 ohms out.
 Topic Commands
Powered By ezboard® Ver. 7.32
