September 17, 2026, 09:50:12 pm
Hoffman Amps Forum image Author Topic: Bias question  (Read 4571 times)
Offline Mr.Death
Bias question
« on: November 22, 2022, 11:02:44 am »
I was biasing my 100w EL34  Traynor YBA3 today and I noticed the colder I biased the amp the higher the plate voltage. At 28MA I had 578 plate voltage, 32MA 574V and 35MA got me 572V to the plates. Does this make sense? Thanks.
Re: Bias question
« Reply #1 on: November 22, 2022, 12:01:10 pm »
Yes, no power supply is perfect, there’s always internal impedance / resistance. Hence as the current drawn from the supply increases, the supply voltage will decrease.
Try measuring HT voltage at the rectifier / reservoir cap with the amp cranking out full power into a dummy load.
HT sag is key piece of protection for valves, without it they’d tend to overdissipate with signal.
« Last Edit: November 22, 2022, 12:03:18 pm by pdf64 »
Offline jewishjay
  • Merrily on my way to nowhere in particular!
    • my Reverb store
Re: Bias question
« Reply #2 on: November 22, 2022, 12:01:34 pm »
Yes, more current draw = lower voltage. That's always the case when adjusting bias. Perfectly normal.
Offline Mr.Death
Re: Bias question
« Reply #3 on: November 22, 2022, 12:29:53 pm »
So if red plating is a result of high plate voltage wouldn't a hotter biased amp( less plate voltage) be less prone to red plating? Seems to be the case in theory or am I wrong? Thanks.
Re: Bias question
« Reply #4 on: November 22, 2022, 12:32:44 pm »
Red plating is not caused by high plate voltage. It's caused by high plate current.
Re: Bias question
« Reply #5 on: November 22, 2022, 01:47:58 pm »
Redplating is Voltage TIMES Current.
Since power supply impedance is normally "low", the lower the current the cooler the tube. The small rise as the voltage un-sags is more than made up by lower current.
Another situation you rarely see today is PS impedance similar to amplifier load. Seen with old field-coil speakers. The raw B+ may be as high as 450V, the FC dropped 200V, the tube ate 250V. Different tube current gave different tube voltage, but for a -wide- range around nominal the tube dissipation hardly changed. (You could burn-up a field-coil if you went crazy.)
Offline Mr.Death
Re: Bias question
« Reply #6 on: November 22, 2022, 06:43:07 pm »
Thanks again guys.
