September 14, 2026, 09:45:48 am
Hoffman Amps Forum image Author Topic: Steve Luckey November project  (Read 3827 times)
Offline isaac_teller
« on: November 25, 2022, 11:26:22 am »
Hello. I built this exactly as per the schematic, except with diodes instead of a 5Y3. All the voltages are within +/- 5%. Sounds great except there is a slight motorboating-type buzz in the preamp. When I turn the master down it's dead quiet. What should I look for  to fix it? Thank you.
http://www.sluckeyamps.com/november/november.pdf
Re: Steve Luckey November project
« Reply #1 on: November 25, 2022, 12:00:54 pm »
Motor Boating may have to do with PS
As you have SS rectifier tray to increase the first filter cap
You can also revise the value of the resistors on PS
« Last Edit: November 25, 2022, 12:09:36 pm by kagliostro »
« Reply #2 on: November 25, 2022, 01:29:05 pm »
Thanx. I'll give it a try.
« Reply #3 on: November 25, 2022, 02:45:17 pm »
I forgot to say
You can also sub the 1N diodes for UF diodes
At least, add an UF diode After the FW or FWB rectifier and before the first e-cap
