September 08, 2026, 07:28:45 pm
Hoffman Amps Forum image Author Topic: Amp Projects  (Read 8874 times)
Offline Lectroid
Amp Projects
« on: November 28, 2022, 02:43:50 pm »
Over the past three years I've built three amps of increasing complexity, with the help of so many people. I thought I should show everyone how they turned out.  (If this is the wrong forum, please move, thanks)
My first, a Bell & Howell 179 conversion.  It's like a 5E3, except with a 6SJ7 Pentode in the first stage.  Very clear and solid and lower volumes, then breaks up into a nice Deluxe growl at higher settings.  Hammond organ 12" speaker.  I did the cabinet and tolex myself.
The second two are of my DR 1-channel AB763, no tremolo.  Cabinet is from Guitar Cabinets Direct, panel by Sandy Henry. and the speaker is a Jensen P12Q.  At 25 Watts, I thought it would be enough but this thing gets loud.  I may have to upsize it.
« Last Edit: November 29, 2022, 10:42:08 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
Offline CrocMule
Re: Amp Projects
« Reply #1 on: November 29, 2022, 09:33:15 am »
Nice work.  The tolex looks pro.
I wouldn't mind seeing a gut shot of the Bell & Howell...
And what's behind door #3?
Offline Lectroid
Re: Amp Projects
« Reply #2 on: November 29, 2022, 10:27:15 am »
@CrocMule,
Thank you.
Door #3 was a Princeton AA964 clone.  I swapped the Fender tremolo circuit for sluckey's Tremor-lator, which worked well.  Never got around to putting it in a cab--I use the chassis to play with circuit ideas.
The B & H Deluxe clone was my very first and it was an ongoing mess for 18 months as I learned what I was doing, and how amps worked, etc.  I rebuilt some sections 2 or 3 times and it's still pretty ugly.  I do have 'Before' pics of the original projector amp.  Also, it was an *extremely* tight chassis so it was a real trial by fire.  I ended up just gutting the chassis.
As you can see, the level of packing in there was amazing, with those old-style components.  Note the actual metal rod that operated a leaf switch to change inputs when a microphone plug was inserted.  All of the circuitry for reading sound off the filmstrip wasn't needed anyway, so I started over as a point-to-point build.
Also, here's the schematic of what I ended up with (after much help from the denizens here).  If I get time today I'll get you a pic of the final circuit.
« Last Edit: November 29, 2022, 10:38:10 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
Offline CrocMule
Re: Amp Projects
« Reply #3 on: November 29, 2022, 10:39:11 am »
Holy cow, that's a tight chassis.  Working in that would make me feel claustrophobic.
Interesting circuit.  How do you like the 6SJ7 in V1?  That's probably covered in an earlier thread.  You got a link?
Offline Lectroid
Re: Amp Projects
« Reply #4 on: November 29, 2022, 10:57:33 am »
Try this:
https://el34world.com/Forum/index.php?topic=26814.msg295241#msg295241
Or search on my user name and you might find some others.
I like the 6SJ7; I'm pretty happy with the sound for a first amp.  In the B&H, it was originally a 6J7 but that tube is very microphonic and several people advised a swap.  I ended up mounting the tube socket on thin grommets, sitting on the chassis, and I have two o-rings on the tube can to soak up any other vibrations.  It's pretty quiet.  I think I may revisit the Volume-Tone area someday but overall it's a good little amp.   (12-14W?)
Here's a B&H rebuild blog by Huw Price on guitar.com:
https://guitar.com/guides/diy-workshop/diy-workshop-bell-howell-filmosound-amp-conversion-part-two/
Too bad the old projectors are getting so hard to find.  I've looked at a lot of them and I think the 179 or 285 are the very best to convert.
« Last Edit: November 29, 2022, 11:04:03 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
Offline bmccowan
  • Better builder than player
Re: Amp Projects
« Reply #5 on: November 29, 2022, 05:52:08 pm »
Very nice. Funny, I have two Filmosound 179s I bought years ago after reading about Ry Cooder's work with them. Every time I opened one up, the clutter scared me and I put the base back on and started something else. The day after TG, I grew some stones and gutted one of them. Who and how were those built?! :w2: everything is just jammed in there. I worked out a schematic, pretty similar to yours, but borrowing more from the very early bassman and a PI from Valco. I am playing around with layout ideas now. Everything so close together calls for true point-to-point, eh?
I'm also changing V1 to a 6SJ7. A few early Fenders and many Gibsons and Valcos used that tube in V1. The EF86 and 5879 are not a lot different. I've built quite a few amps with pentodes in V1 and like it a lot, I've also put them in V2, driving them with a triode in V1; ala Matchless Clubman and Merlin recommendations - cleaner, smoother, louder, but nothing works better for bottleneck slide than a pentode in V1 IMO - pure juke joint.
Mac
John Prine
Offline Lectroid
Re: Amp Projects
« Reply #6 on: November 30, 2022, 11:27:25 am »
@CrocMule,
Here's the interior shot you want of my build. 10"x7"x2"...tight.
@bmccowan,
Someone smarter than me said it would be Absolutely The Worst first project I could take on.  So I went ahead anyway, and proved him right.  But I learned a lot, so I guess it was worth it.  The density of the original layout still blows me away when I think about it, especially all those little metal plates in odd places to kill interference between close-packed sections.  And the whole thing had to sit inside a rumbling electrical machine and reproduce good sound.  Amazing.
I'm also having thoughts of revisiting the 179, cleaning up the layout, etc.  And maybe tweaking the circuit a little.  I had in mind to check out some of the early 50s amps to see how they used pentodes in V1.  Do you have a schematic you're willing to share?
Magis bos clocca!
Free Beer Tomorrow!
Offline dtbradio
  • Tube Nube's R Us
    • DTB Radio Online
Re: Amp Projects
« Reply #7 on: December 01, 2022, 03:26:40 pm »
I may have missed something in replies, but do you have any audio/video files of the amps in action? Would love to hear samples! I'm working on my very first tube guitar amp project, and enjoy comparing results with other's builds.
It ain't about who's got the biggest tube, its about knowing how to use it!
Offline bmccowan
Re: Amp Projects
« Reply #8 on: December 02, 2022, 07:29:42 am »
Sure Lectroid - I'll post what I intend for the one I just gutted, and a couple others, later today. For other amps - there are many. Fender only had a very few. Most early Gibson, and Valco (Supro, National, Oahu) amps used 6SJ7 in V1. Lots of schematics right here on Doug's schematic pages. Leon C has collected many such amps, is a great guitar player, and demos them on YouTube.
Mac
John Prine
Offline dmp
Re: Amp Projects
« Reply #9 on: December 02, 2022, 08:51:04 am »
Hi LectroidI'm helping a friend with a filmosound 179 right now.Unless you already changed it, you might want to look at the tone stack before doing anything else. These have a cool James / Baxandell tone stack design - BUT the tone pot is a dual 3M that (I think) counter rotates bass and treble. If you try separate bass/treble pots you will have a huge range increase & improvement on the tone you can get.The V1 pentode stage is wired pretty standard - other than the high grid resistor (1M). The Vox amps used a variable switched set of capacitors after this stage to make a HPF (less bass).
You can be deliberate in what you want from the frequency filtering - ie. a HPF leaving V1 combined with the tone stack design. Check out the "tone stack simulator web"
What are the codes on your transformers? My buddy has a version with 606 (Schumacher) and it sounds fantastic.
Offline bmccowan
Re: Amp Projects
« Reply #10 on: December 02, 2022, 10:17:01 am »
dmp - are you sure that amp is a 179? I think that might be a different model: 385? No dual pot in either of the two 179s I have.
Mac
John Prine
Offline Lectroid
Re: Amp Projects
« Reply #11 on: December 02, 2022, 11:47:39 am »
@dmp,
My B&H transformers both have a 138 code - Stancor.  Both PT and OT are over-powered for the amp IMO.  Lots of reliability built-in.
I agree with bmccowan that your chassis is likely a 385.  Do you have schematics?  The 385 definitely shows the dual tone pot.  The 179 has a rather different (but still interesting) tone circuit.  At the time I could not understand how it worked so I used a Deluxe 5E3 circuit.   I have a doc with most B&H tube model schematics.  If you PM me with your email, I'll copy you.
@dtbradio,
I don't have any samples right now, maybe I'll lay something down.  What are you working on for your first project?
Magis bos clocca!
Free Beer Tomorrow!
Offline dmp
Re: Amp Projects
« Reply #12 on: December 02, 2022, 12:58:13 pm »
Just checked, my mistake, it's a 385 that we are working on.
Offline bmccowan
Re: Amp Projects
« Reply #13 on: December 03, 2022, 08:11:20 am »
Lectroid - attached is the starting point schematic for my 179 "Schoolie" - fond memories from Jr High school of the AV department wheeling in a Filmosound to show us Reefer Madness, or the Horrors of Gonorrhea.
Also attached are a few Gibson Schematics with 6SJ7 in V1. Merlin has a good chapter on pentodes on his Valve Wizard site.
Mac
John Prine
Offline Lectroid
Re: Amp Projects
« Reply #14 on: December 04, 2022, 11:48:12 am »
@bmccowan,
Many thanks for all this.  I worked as a student projectionist long ago at San Diego State.  One week I had to watch "Seal Island" three times--they didn't pay me enough to endure that.  But what amazingly complex and tightly-packed machines, back when American manufacturing was at its peak.
I can't read the 179 schematic--for some reason Autodesk is not letting me log in, maybe cause I'm on a Mac?  Is there any chance you might have a PDF or JPG?   No worries if not.
Thanks again
Magis bos clocca!
Free Beer Tomorrow!
Offline bmccowan
Re: Amp Projects
« Reply #15 on: December 04, 2022, 12:37:37 pm »
Trying a GIF - I usually mess this up
Mac
John Prine
Re: Amp Projects
« Reply #16 on: December 04, 2022, 12:48:25 pm »
It's not an Autodesk file. That file was created by a freeware program called ExpressSCH.
There is a free MAC program called JSchem that can also view those *.sch files.
Hoffman even has a forum dedicated to ExpressSCH and JSchem.
Offline Lectroid
Re: Amp Projects
« Reply #17 on: December 04, 2022, 02:15:44 pm »
@bmccowan,
Got the GIF, it opened just fine, thanks.  If I may ask, why'd you used a paraphrase PI instead of a cathodyne?
@sluckey,
I try to learn 3 new things every day--it's not often I get them in one post!  :laugh:   On my machine SCH file were linked to Eagle CAD from Autodesk, a subscription service (well, used to be) which I avoid when I can.  Never knew about JSchem, just avoided SCH files.
But I downloaded JSchem and can now open SCH files. Never able to before so this is great.  Thanks again.
Magis bos clocca!
Free Beer Tomorrow!
Offline bmccowan
Re: Amp Projects
« Reply #18 on: December 04, 2022, 04:41:25 pm »
paraphrase PI instead of a cathodyne? No particular reason, other than I like early Valco amps and most use that type of PI. Other than that, its all sort of a long ongoing experiment for me: play it for a while, see how it sounds, change it up maybe. I always find it interesting how the different stages from different circuits work well together. I think Sluckey said at some point, pick a power amp and a preamp and glue them together. That's pretty much what I do. I'm not knowledgeable enough to invent something new. :icon_biggrin:
Mac
John Prine
Re: Amp Projects
« Reply #19 on: December 04, 2022, 07:18:54 pm »
....I had to watch "Seal Island" three times--they didn't pay me enough...
You can watch it again! The drama! The plotting! Romance. Suspense. Melodrama! Females in furs!
