September 18, 2026, 12:57:04 pm
Hoffman Amps Forum image Author Topic: SF Princeton Rev: distorting with reverb tank plugged in  (Read 4571 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: November 29, 2022, 07:30:09 pm »
Hello!  Long time and I hope alls well. Have a 72 Princeton reverb on the bench that’s distorting heavily with the reverb tank plugged in and reverb level above 4. Level acts like a gain pot lol.  Amp arrived with a decent cap job completed. Thought maybe the screen filter cap node was going south in the ce cap but it’s fine. Voltages look great with no leaking coupling caps or conductivity on the board. Has anyone seen this before?
Cheers!
« Last Edit: November 29, 2022, 11:41:15 pm by fdesalvo »
FDeSalvo,
Principal Engineer & Owner,
Offline Latole
Re: SF Princeton Rev: distorting with reverb tank plugged in
« Reply #1 on: November 30, 2022, 03:42:34 am »
You need a scope to see how look the input signal at the reverb tank and what s look a the reverb tank output.
Clean at the input and distortion at the output ; replace the reverb tank
Distortion at the input; check amp stage before.
Try new cable; any hi-fi rca cable do the job
« Reply #2 on: November 30, 2022, 05:29:51 am »
Does the amp distort with the reverb footswitch turned off?
Does the amp distort with the reverb pot set to zero?
Offline fdesalvo
  • "...I can walk!!"
« Reply #3 on: November 30, 2022, 08:13:08 am »
- No scope access, I’m afraid.
- I’ve already tried with known good test tank and cable set.
- Tube change didn’t help
- I’ll see if the amp distorted with the reverb at 0, can’t recall offhand. I believe it sounded pretty clean with the level set to 0.
- Haven’t tried with footswitch plugged in. Have been testing without
Will update Ty!
FDeSalvo,
« Reply #4 on: November 30, 2022, 09:06:43 am »
Well use a gator clip lead to ground the footswitch center pin. Any distortion?
Offline fdesalvo
  • "...I can walk!!"
« Reply #5 on: November 30, 2022, 09:45:53 am »
I removed the cathode bypass cap on the recovery stage and it resolved the issue. Strange times at the shop. I’m going to install smaller cathode bypass caps on the preamp to trim some additional blub. Ty all!
FDeSalvo,
Offline Latole
« Reply #6 on: November 30, 2022, 12:49:42 pm »
Bypass caps give boost to a tube
Offline fdesalvo
  • "...I can walk!!"
« Reply #7 on: November 30, 2022, 01:21:48 pm »
Indeed. Removing that and cleaning up the lead dress around the recovery tubes did the trick.
FDeSalvo,
