September 18, 2026, 11:55:08 am
Hoffman Amps Forum image Author Topic: Seeking for el84 amp schematics with concertina PI  (Read 5859 times)
« on: December 02, 2022, 11:22:16 am »
I'm looking for schematics of amps with concertina PI and el84 as power tubes
Many Thanks
« Last Edit: December 02, 2022, 12:04:12 pm by pdf64 »
Offline 66Strat
Re: Seeking for el84 amp schematics with concertina PI
« Reply #2 on: December 02, 2022, 12:18:44 pm »
The EA35 schematic looks like a winner.
Regards,
JT
« Reply #3 on: December 02, 2022, 01:26:26 pm »
Many Thanks pdf64
66Strat unfortunately I was looking for a 3 triodes preamp and the EA35 is the only among 3 that has a pre with only 2 triodes
all starts from the request of a forumer at DIYItalia, he has a Geloso 1022 and want to convert it to a guitar amp
and it uses 3 triodes as pre the fourth is a concertina PI
« Last Edit: December 02, 2022, 01:28:58 pm by kagliostro »
Offline danhei
« Reply #4 on: December 03, 2022, 07:34:39 am »
@kagliostro have you/he tried running a guitar into the Micro and Fono inputs? It might already sound pretty good as it seems pretty close to a guitar amp already. And the design looks good. At a guess Micro will have too much gain but Fono could sound pretty sweet.
If you start modding I’d recommend to mostly leave V2 and the power amp alone. Maybe change the first stage from grid leak bias to a conventional cathode bias stage. If it’s too bassy reduce the coupling caps. Harsh distortion try disconnecting the NFB or increasing the value of the 47K NFB resistor.
« Reply #5 on: December 03, 2022, 12:48:45 pm »
Ciao danhei
I've one but at this time isn't mine that is planned to be restored and modded for guitar use
Micro inputs 4mV (0.5MOhm) (-82.8dB)
Micro gain +118dB
Fono inputs 130mV (1MOhm) (-54.2dB)
Fono gain + 89.4dB
Bandwidth 30Hz - 15000Hz
Power 20-30W
The choice of the guy at DIYItalia fell on a Merlin's Mid Gain preamplifier so will be used V1 and 1/2 V2, the other 1/2 of V2 is and continues to be the Concertina PI
Years ago one other guy modded a 1020 A, he stopped to the first triode with something like this
and he told the sound of the amp resulted no longer as boxy and gloomy as before and was happy with that, so you are not wrong at all
Offline Cliff Rogers
« Reply #6 on: December 04, 2022, 05:36:20 am »
« Reply #7 on: December 04, 2022, 05:50:36 am »
I have not built this one but it's an idea I drew up a few yrs ago.  I do currently play a 6BM8 amp that's similar using a mosfet CF and 5879 in V1
« Reply #8 on: December 04, 2022, 07:57:20 am »
Thanks Cliff Rogers & Tubenit
I like the James Tone Control in the Lamington and also the pentode as V1 with the Source Follower in V2 of the HoSo56
Both are interesting circuits
I'll submit it to the interested guy
@ Tubenit
I've find a layout for an HoSo56 with FX, there is one specific for the version of HoSo56 you posted here ?
The Geloso G1/1020 A has a very compact Eyelet Board (two rows) the measure of the Board are 3.7cm x 16.5cm and there are 21 eyelets on two rows
it has a montage on the chassis a la Hoffman Stout, sockets and pot are on the same side
« Last Edit: December 04, 2022, 08:25:35 am by kagliostro »
« Reply #9 on: December 04, 2022, 11:35:37 am »
Yes, but it's for 6V6's, so just change the power tube and cathode resistor out in the drawing.
If you don't have access to 5879 pentodes then you could use a 6AU6 or a 5654 instead.
« Last Edit: December 04, 2022, 11:37:46 am by tubenit »
« Reply #10 on: December 04, 2022, 01:50:37 pm »
Here's another circuit to add to your collection. It's the AO-43 reverb amp from a Hammond organ.
« Reply #11 on: December 04, 2022, 02:07:36 pm »
Many Thanks Tubenit
That is really a very good documentation
Many Thanks also to you Steve
Only that it sounds a bit sibylline to me, to modify a Geloso PA amplifier for guitar use, you share the schematic of an organ amplifier that is normally used as a basis for conversions into a guitar amplifier  :icon_biggrin: :icon_biggrin: :icon_biggrin: :laugh: :laugh: :laugh: :l2: :l2: :l2:
However Many Thanks  :thumbsup:
