August 06, 2026, 01:38:49 pm
Hoffman Amps Forum image Author Topic: AC30 clone outer tubes in quad redplating?  (Read 4307 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: December 07, 2022, 03:01:46 pm »
Hello, all. Have any of you seen this before? Newish hayseed 30 build no leaky caps resistors test good. Very haphazardly assembled! Known good tubes redplate there as well.
Tia!
« Last Edit: December 07, 2022, 05:26:54 pm by fdesalvo »
FDeSalvo,
Principal Engineer & Owner,
Re: AC30 clone outer tubes in quad redplating?
« Reply #1 on: December 07, 2022, 05:41:00 pm »
Sounds like a perfect breeding ground for gremlins.   :icon_biggrin:
Offline JPK
« Reply #2 on: December 08, 2022, 11:56:34 am »
Please see Slucky's signature.
I love tubes
Offline fdesalvo
  • "...I can walk!!"
« Reply #3 on: December 08, 2022, 12:43:28 pm »
I sorted it out gentleman. Dying battery in my meter was masking the nearly 400v on the plates lol.  I swapped in an old 5R4 rectifier tube and she’s down to 306 V. No issues. Thank you.
FDeSalvo,
« Reply #4 on: December 08, 2022, 05:06:22 pm »
If you have only replaced 2 tubes in an output tube quad, you can get problems with one of the pairs under heavy signal conditions in some amps (when the 'hotter' pair ends up drawing more current- particularly in amps like 1959 Super Lead 100 Marshalls with EL34 quads where the B+ is 500). Which is why you need to be careful with quads.
Offline fdesalvo
  • "...I can walk!!"
« Reply #5 on: December 08, 2022, 05:07:44 pm »
Truth. I tested four new ones.
FDeSalvo,
