August 06, 2026, 06:41:39 pm
Hoffman Amps Forum image Author Topic: Revisit- Fender Super Twin- New Project  (Read 5900 times)
Offline pbman1953
« on: December 08, 2022, 05:22:20 pm »
The Super twin has been working fine but I have 1 gain question. At the front end on V1-pin 8 I replaced the 750/3v to a 10 uf. I seemed to have lost some gain and attack. Should I go back to the 750 or change to another value?
Re: Revisit- Fender Super Twin- New Project
« Reply #1 on: December 08, 2022, 05:59:59 pm »
yes
Offline pbman1953
« Reply #2 on: December 08, 2022, 06:04:16 pm »
ok, thanks
Offline pbman1953
« Reply #3 on: December 09, 2022, 06:41:28 am »
I still have the original white 750 polarized cap. Should I use it or replace due to its age?
« Reply #4 on: December 09, 2022, 07:17:04 am »
yes
Offline pbman1953
« Reply #5 on: December 09, 2022, 07:38:36 am »
Thanks, just to be sure. This is a 750 uf?
« Reply #6 on: December 09, 2022, 07:46:45 am »
Hey, you didn't ask permission to remove it. You don't need permission to put it back.  :wink:
Offline pbman1953
« Reply #7 on: December 09, 2022, 07:48:20 am »
True, just want to be sure if the value in in"uf"
« Reply #8 on: December 09, 2022, 07:59:14 am »
yes
Offline pbman1953
« Reply #9 on: December 09, 2022, 08:00:03 am »
Thanks!!!
« Reply #10 on: December 09, 2022, 08:02:36 am »
You know, that was answered back in August.
Offline pbman1953
« Reply #11 on: December 09, 2022, 08:05:50 am »
well, your memory is better than mine :icon_biggrin:
Offline pbman1953
« Reply #12 on: December 09, 2022, 03:04:37 pm »
I've looked at many other bass amp front ends. Traynor and Sunn both use 220uf for that position. Fender has used 25 and 220.
I have a 220 and a 330. Will the 750 be that much different? I'm coming from a 10
« Reply #13 on: December 09, 2022, 03:15:22 pm »
Just do it!
Offline pbman1953
« Reply #14 on: December 09, 2022, 04:40:03 pm »
Well I tried the 220 , 30 & old 750.
The old 750 did have the best attack. I stayed with the 330 because it was close and new. Otherwise I can put the 750 back in
