August 06, 2026, 03:42:30 pm
Hoffman Amps Forum image Author Topic: Power tube tremolo pot failure precaution  (Read 4025 times)
Offline BrainDeadAmps
  • Trial and error
« on: December 09, 2022, 12:03:37 am »
When using a Princeton style output tube bias tremolo, I was considering wiring a large resistor from the wiper to the ground lug on the intensity pot.
My thinking is that is would act as a backup ground reference for the output tubes in-case the pot fails, the same way a resistor is added to post phase inverter master volume pots.
cheap protective measure or any reason not to?
« Last Edit: December 09, 2022, 12:14:28 am by BrainDeadAmps »
Re: Power tube tremolo pot failure precaution
« Reply #1 on: December 09, 2022, 03:24:29 am »
Good idea, I don’t see a downside  :thumbsup:
« Reply #2 on: December 09, 2022, 05:29:28 am »
Do you have a cathode biased PR? All I've ever seen were fixed bias. Either way, still a good idea.
  • Trial and error
« Reply #3 on: December 09, 2022, 07:41:06 am »
Thanks for the responses guys!
Sluckey, the amp I’m currently building is cathode biased.
