September 19, 2026, 02:18:24 am
Hoffman Amps Forum image Author Topic: Power supply daisy chain isolation  (Read 10183 times)
g-man
  • Guest
« on: December 15, 2022, 08:24:31 pm »
Deleted
« Last Edit: August 06, 2024, 02:57:38 pm by g-man »
Offline acheld
Re: Power supply daisy chain isolation
« Reply #1 on: December 16, 2022, 10:24:27 am »
I use a 1Spot Pro CS6 and daisy chain a bunch of pedals off of the various output channels.  I have not had problems with noise in doing so.
Maybe I'm naive about this, but I don't hear any difference when I'm using dedicated (eg, 1 pedal per power wart) vs the 1Spot.
Possibly a solution in search of a problem?
« Reply #2 on: December 16, 2022, 11:10:02 am »
Most pedals would draw as little as 10 mA up to maybe 200 mA.
A 10ma draw thru that 100Ω would drop the voltage down to 8V for the pedal. OK for a lot of pedals. But...
A 200ma draw through a 100Ω would cause a 20V drop across the 100Ω. But wait! You done run into the wall. A 9V battery can only push 90mA through a 100Ω and that leaves zero volts for your pedal. Better rethink this.
I built this simple power supply that handled nine pedals with no isolation resistors.
g-man
  • Guest
« Reply #3 on: December 16, 2022, 12:41:04 pm »
Deleted
« Last Edit: August 06, 2024, 02:56:09 pm by g-man »
Offline RadioComm
« Reply #4 on: December 16, 2022, 04:20:47 pm »
+1
