September 17, 2026, 10:37:03 am
Hoffman Amps Forum image Author Topic: How to identify part values....  (Read 5996 times)
Offline mmrxcsr01
« on: December 16, 2022, 10:23:54 am »
...specifically, paper electrolytics. I have an old, old amp, no schematic, and the cardboard tube is just completely unreadable. I have searched every way I can think of online, it's not in Doug's files....any suggestions? TIA....
Offline acheld
Re: How to identify part values....
« Reply #1 on: December 16, 2022, 10:26:45 am »
Is it a commercially built amp?  Pictures?
Offline mmrxcsr01
« Reply #2 on: December 16, 2022, 10:35:18 am »
It's 1949 Silvertone, model 1304, 5u4, a pair of 6l6's....12sj7, 12sn7, 7c7. Field coil 12". Passes signal, but with a bad hum. Sorry, no pix....from what I've been able find from a few searches, this was a transition model, only produced for 6 months...
« Reply #3 on: December 16, 2022, 11:26:57 am »
This model 1303 looks like a close match. I'd use these cap values...
     https://el34world.com/charts/Schematics/files/Silvertone/Silvertone_1303.pdf
Offline mmrxcsr01
« Reply #4 on: December 16, 2022, 11:48:28 am »
Thanks Slucky...so 8mfd at 450vdc should about cover it....Merry Christmas.
« Reply #5 on: December 16, 2022, 12:13:18 pm »
Silvertone wudda used whatever they could get (post-war shortages).
Yes, a fist full of 8uFd seems likely.
The field-coil speaker was already going out of style. But so were large parlor radios, and maybe Silvertone had a 6-month supply to use-up.
Offline mmrxcsr01
« Reply #6 on: December 16, 2022, 12:33:28 pm »
Thanks PRR, that thought hadn't occurred to me...here's a pic, from online...
« Reply #7 on: December 16, 2022, 01:33:53 pm »
Three of those caps are filter caps and should be rated about 450v. The fourth cap is a cathode bypass and only needs to be rated for 50V.
You can buy all four caps for under $10 at AES is you use MOD brand.
Offline mmrxcsr01
« Reply #8 on: December 16, 2022, 02:49:49 pm »
Sluckey, what about the pot for the trem? It's missing, and a weird 650k value. It controls the speed; do you think a 500k would suffice?
« Last Edit: December 16, 2022, 03:00:36 pm by mmrxcsr01 »
« Reply #9 on: December 16, 2022, 04:29:57 pm »
I would use a 1M pot. Bigger values can give you a slower speed and still give the same fast speed as a smaller pot.
Offline mmrxcsr01
« Reply #10 on: December 17, 2022, 08:57:53 am »
Thanks again all, much appreciated. Merry Christmas....
