September 17, 2026, 02:05:05 pm
Hoffman Amps Forum image Author Topic: 5840 tube question  (Read 6302 times)
Offline Oddvar
5840 tube question
« on: December 16, 2022, 12:34:57 pm »
Might be the wrong place this, but I wonder if anyone could tell how to turn a 5840 tube into a triad, I need to know how the eight pins can be connected to: anode, H+, H-, gate and cathode?  Eight pins into five points. I have looked everywhere, but info is a bit vague.  Best advice so far is in the pic, but I am in the dark.  Some say one shouldn't kee pins unconnected, if so, who should go where?
Re: 5840 tube question
« Reply #1 on: December 16, 2022, 01:18:32 pm »
This tube has wire leads instead of pins. It does not plug into a tube socket.
Lead 1 connects to the grid circuit.
Lead 2 connects to the cathode circuit. Just tape off leads 4 and 8 since they are internally connected to lead 2.
Connect leads 5 and 7 together. This makes the tube a triode. Connect the two leads to the plate circuit.
Connect leads 3 and 6 to the 6.3V filament supply.
« Last Edit: December 16, 2022, 01:21:29 pm by sluckey »
Offline Oddvar
« Reply #2 on: December 16, 2022, 03:46:34 pm »
Great Sluckey, thank you ever so much.
« Reply #3 on: December 16, 2022, 05:31:36 pm »
But can and do have sockets specifically for them.
https://www.dropbox.com/sh/u690mpdw8qxiqid/AAAPv8EpvgAJnfk5NznxyMbza?dl=0
They (sockets) are scarce and are a pain to solder to - Typically I use 24-26AWG solid core teflon insulated wire. Those pics are of a pedal I was working on. Two 6788 pentodes and a 6948 dual hi-mu triode. Power is provided by a wall-wart to a 5W DC-DC converter supplying ~200VDC for the B+ rail. Wall wart provides 15VDC@3A and we regulate 6VDC for filaments with a 7806 linear v. reg.
--Pete
« Last Edit: December 16, 2022, 05:58:45 pm by kagliostro »
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #5 on: December 16, 2022, 05:48:24 pm »
perfect timing for me as I am triode strapping a #78 pentode and 6A7 pentagrid (still have two grids on this one to deal with)
I have read that if you add a 100R between screen and plate it works better because it prevents parasitic oscillations, whatever that is :-)  http://www.audiodesignguide.com/New2A3/ETF06TS.pdf
also, Can we use the same pentode curves for setting bias when operating as triode?
