September 17, 2026, 07:23:05 am
Hoffman Amps Forum image Author Topic: Power switch pop  (Read 7083 times)
Offline Leevi
    • Rikstone
Power switch pop
« on: December 17, 2022, 05:27:52 am »
Have handled this earlier but thought to take it up again with some solutions that work for my current issue. Actually my question is which one of those 4 alternatives do you recommend and are they all safe as long term solution?Alternative 4 has a drawback since it consums current even if the amp is not turned on.
/Leevi
« Last Edit: December 17, 2022, 05:48:26 am by Leevi »
Offline Williamblake
Re: Power switch pop
« Reply #1 on: December 17, 2022, 07:03:33 am »
What would pop with a tube rectifier i wonder. No4 looks pretty stupid for obvious reasons as already been said.
Offline Leevi
    • Rikstone
« Reply #2 on: December 17, 2022, 07:15:30 am »
It pops when I turn off the amp. I have also noticed that it is depending on the PT.
In this particular case I changed the PT and this issue did not exist with the previous one.
/Leevi
« Reply #3 on: December 17, 2022, 07:26:25 am »
Maybe it is the relay not the rectifier?
Offline Leevi
    • Rikstone
« Reply #4 on: December 17, 2022, 08:12:18 am »
relay
/Leevi
« Reply #5 on: December 17, 2022, 08:18:52 am »
The change in fragreance is causing the pop. The chanelle switching. Definately not the Pt or rectifier. You would be first. Seriously, what popping circuit are you talking about?
« Reply #6 on: December 17, 2022, 08:31:55 am »
On a side note, to cause a pop you would have to have someting in your circuit that changes signal voltage speed-of-sound-fast. A vacuum tube rectifier power supply on planet earth would not be able to do that me is sure.
Offline Leevi
    • Rikstone
« Reply #7 on: December 17, 2022, 08:38:25 am »
Yes, the source of the pop can be anywhere in the signal path but in this case the behavior is different with the old and new PT. And all the fixes I listed are located in the power supply.
I hope someone could give a technical explanation for power switch pop which is very common in tube amps.
/Leevi
« Reply #8 on: December 17, 2022, 08:45:58 am »
"power switch pop which is very common in tube amps."
That is news to me. So i am stepping back for somebody else to ask for a shematic.
Offline Leevi
    • Rikstone
« Reply #9 on: December 17, 2022, 09:32:32 am »
Maybe I should add that it is common in the amps without standby switch.
/Leevi
« Reply #10 on: December 17, 2022, 09:38:43 am »
I think popping when powering down is reasonably common.
To save anyone else the trouble, a PMR209 is a RC snubber https://www.robot-electronics.co.uk/products/pmr209.html
I suggest to combine 3 and 4.
And 2, but moved to the primary.
That’s possibly more mitigation than absolutely necessary, but the multi pronged approach should resolve the issue.
« Last Edit: December 17, 2022, 09:57:10 am by pdf64 »
« Reply #11 on: December 17, 2022, 09:45:43 am »
/Leevi
Sounds like all the amps i ever built. Never had a pop ever. Begging to be educated.
Even the solid state rectified amp with 6 EL34s i had did not give a noise worth writing home about when powering on or off. I am still thinking the problem is somewhere else.
« Last Edit: December 17, 2022, 10:14:58 am by Williamblake »
Offline Leevi
    • Rikstone
« Reply #12 on: December 17, 2022, 12:05:00 pm »
Here is discussion of this topic in another forum. My case concerns 5D3.
https://www.tdpri.com/threads/which-power-switch-pop-solution-for-5e3.1058180/
/Leevi
« Reply #13 on: December 17, 2022, 12:48:10 pm »
Just use Rob's simple solution. Heck, a .01µF cap looks like a 265K resistor to 60Hz line. Very small current when switch is off.
Offline Leevi
    • Rikstone
« Reply #14 on: December 18, 2022, 12:30:01 am »
I ended up to use PMR209 (100n+100R) even if the idle consumption is ~8mA.It works great, you can't even hear a small snap when switching off.
/Leevi
