September 08, 2026, 07:15:24 pm
Hoffman Amps Forum image Author Topic: Adding photos trouble.  (Read 20772 times)
Offline zapped
« on: December 22, 2022, 07:56:04 am »
Good morning. I recently started a tread about a West amp and could not figure out how to add photos. I only have an iPhone/iPad to work with. I have to confess to be digitally challenged so it may be above my skill set. I found the forum threads for how-to’s but didn’t recognize a solution. Thanks for your patience. Ed
Re: Adding photos trouble.
« Reply #1 on: December 22, 2022, 08:15:50 am »
Look below the text input box and you should see a link called "Attachments and other options". Click on that and follow the instructions. Click the "Choose File" button to open a window showing the files on your device. Navigate the folder structure to find the desired file. Be sure that your file type is in the list and the size limits are not exceeded.
« Reply #2 on: December 22, 2022, 08:19:39 am »
Go here and read this
https://el34world.com/Forum/index.php?topic=464.0
if you are having trouble resizing images, that post has a link where you can do that on a web site
Offline zapped
« Reply #3 on: December 22, 2022, 11:46:41 am »
Thank you moderators  :icon_biggrin:
