September 15, 2026, 10:02:49 am
Hoffman Amps Forum image Author Topic: Geloso G1 1020 A from PA to Guitar Amp (The Power Section Mod)  (Read 5584 times)
« on: January 02, 2023, 02:18:50 am »
The original schematic of the amp is this
I was advised to put some mods in place
I decided to renounce to the Local NFB on the Power Tubes
but I'm still undecided if adopt the other mod eliminating something that seems to be there to avoid self-oscillations, a mod that I would mainly do to reduce the number of components on a board that is somewhat small in size
Adopting that elimination mod this is what I've draw
I've a doubt, as I don't know well the Concertina PI, is that 1M resistor connected between pin #7 and the junction of the RK resistors to be eliminated ? is that part of the autooscillation prevention as seems to me    :w2:
One other thing, the Power Tube Grid Stoppers are disegual, one is 1K and the other is 47K .... difference it will be better I maintain or will be better to put those resistors of an equal value, 2 x 1K or 2 x 47K ?
The .01 coupling cap between the Volume wiper and pin #7 of the PI is to be added (as advised to me) or it can be shun ? Same thing for the 470K to be added as Grid Stopper at pin #7 of the PI ....
Many Thanks
« Last Edit: January 02, 2023, 02:23:34 am by kagliostro »
Re: Geloso G1 1020 A from PA to Guitar Amp (The Power Section Mod)
« Reply #1 on: January 02, 2023, 08:07:13 am »
The 1M is necessary to establish bias.
I would use equal resistors. 1.5K, 5.6K, and 8.2K are common values used with EL84s.
That cap is necessary to prevent the volume pot from upsetting the grid bias. There is a high dc voltage on the concertina cathode and the grid is bootstrapped through the 1M, so there will be a big dc voltage on the grid as well. I've never used the 470K grid stopper but some newer designs consider it as an improvement.
« Reply #2 on: January 02, 2023, 10:51:47 am »
Many Thanks Steve
I really was thinking wrong about the 1M resistor, didn't considered the bias of the triode (me stupid)
Also the .01 cap was useless in my mind but now I understand well
If I've read about the Concertina I really forgot near all   :BangHead:
OK for all the Grid Stopper, this is the easiest part to understand
Many Thanks Again
« Last Edit: January 03, 2023, 02:12:03 pm by kagliostro »
