September 08, 2026, 06:46:43 pm
Hoffman Amps Forum image Author Topic: 20W single ended 1x12 combo with trem and reverb  (Read 17849 times)
Offline mistersnitz
« on: January 02, 2023, 02:34:21 pm »
I've posted this before but my thread got corrupted so here is my current layout and schematic for my single ended amp loosely based off of Uncle Doug's Tremo-Verb build.
Re: 20W single ended 1x12 combo with trem and reverb
« Reply #1 on: January 09, 2023, 12:14:18 am »
Have you built it?
« Reply #2 on: January 09, 2023, 06:31:59 am »
Layout... OT blue wire should connect to second filter cap.
« Reply #3 on: January 09, 2023, 10:49:46 am »
470k grid stoppers + 470k shared grid leak is wonky.
Look at 6V6 manufacturer info; the limit on grid circuit resistance in self bias is 0.5M per valve. You are 3x over that.
The facility to reduce bias to zero seems rather poor practice.
Offline mistersnitz
« Reply #4 on: January 14, 2023, 04:43:36 pm »
Timbo I have not had the time to work on the project, hopefully soon. Also I wanted to get some feedback on the schematic and layout before starting anything.
Thanks Sluckey I will make the correction to the layout!
« Reply #5 on: January 15, 2023, 02:24:27 am »
No worries
The reason I ask is I'm not really into SE amps although I have built a parallel SE with a pair of 6GW8's and it sounded great.
SE amps have their greats but generally low wattage 5-10w
Haven't heard what a SE 20w would sound like.
« Reply #6 on: January 15, 2023, 05:13:15 am »
fwiw, I've build a few in this range, the typical reply from the guitarist, that test drive for me;
"This thing is LOUD, this can't be a 20W amp"
most of mine are head-units through a 2 X12.
« Reply #7 on: January 15, 2023, 08:17:45 am »
2 parallel 6L6s?
« Reply #8 on: January 15, 2023, 09:37:45 am »
they ain't labeled
I get there with a single KT88, ~420vdc, dissipating ~42W, and ~60Vac ready to drive it, all the way to square-waves  :icon_biggrin:
« Reply #9 on: January 15, 2023, 10:17:33 pm »
they ain't labeled
Or 2 parallel 6L6GC fully driven with optimum efficiency
« Reply #10 on: January 16, 2023, 01:04:23 am »
With 300V B + 250V G2 a GU50 in SE is able to perform 18W
As datasheet you can refer also to the EL152 (civil version of the LS50/GU50 tube)
A friend is building a 2 x GU50 in PSE amp
« Last Edit: January 16, 2023, 02:14:16 am by kagliostro »
Offline Tirol29
« Reply #11 on: January 17, 2023, 01:12:04 pm »
hello,
what will happen when V5 or V6 bias pot (2.5k) become a short ?
« Reply #12 on: January 17, 2023, 01:16:32 pm »
Tubes will quickly die.
« Reply #13 on: January 19, 2023, 09:39:37 am »
I never tried but this seems a better way to have an adjustable Cathode Bias
Offline jordan86
« Reply #14 on: January 20, 2023, 09:09:10 am »
This looks like the ax84 layout. I have this in one of their SEL builds that I’ve tweaked into a more plexi preamp. It works very well. I had a bad tube that burnt up the original 2W pot and replaced with a 5W wirewound CTS pot a few years back. I believe it is 1K. I can bias anything from a 6V6 to a KT88.
« Last Edit: January 20, 2023, 09:14:27 am by jordan86 »
Offline mistersnitz
« Reply #15 on: February 05, 2026, 03:44:47 pm »
Bringing this back from the dead!
There's been some progress made, power supply and preamp turretboards are populated and soldered minus the flying leads and I've quickly mocked up the layout with the chassis to figure out placement of components. See attached pictures
I've made some (a lot of) modifications to the schematic and layout previously posted, I'll update when I start debugging and get closer to a final revision
« Reply #16 on: February 05, 2026, 04:55:46 pm »
fwiw;
the OT might be problematic that close to the sensitive signals in the pre
Offline mistersnitz
« Reply #17 on: February 05, 2026, 08:13:33 pm »
fwiw;
Not much real estate to relocate the OT. If needed I can add a shield plate to create some separation, but unless I switch to a larger chassis that's where it's going to live for now.
Offline mistersnitz
« Reply #18 on: April 17, 2026, 10:02:56 am »
Finally got this thing built and tested properly. Some tweaks needed here and there and a reverb driver tube to replace but overall really happy with the outcome. I was surprised by the absence of hum with the chassis just sitting on the speaker cab in our rehearsal space with no shielding (unless you crank everything almost wide open)
Next steps are balance tweaks between the selectable tone stacks, replacing the 12AT7 that died due to a cold solder on one cathode pin of the reverb driver and resolve some thumping of the trem circuit
Oh and getting started on the combo cabinet!
« Last Edit: April 17, 2026, 04:29:12 pm by mistersnitz »
Offline mistersnitz
« Reply #19 on: May 22, 2026, 11:37:18 am »
Cabinet is done, except for rear panels mounting holes (waiting on hardware). I am going to transfer the Celestion Alnico from my 5E3 into it but I am not 100% sure if it's going to stay there, I have a WGS ET65, Invader or Reaper as possible options.
Offline Lectroid
« Reply #20 on: May 23, 2026, 09:18:30 am »
Very nice cabinet!  One of the best I've seen here.  :bravo1:
Magis bos clocca!
Free Beer Tomorrow!
