September 17, 2026, 10:42:28 pm
Hoffman Amps Forum image Author Topic: Power amp schematic on this site question  (Read 8050 times)
Offline joesatch
  • save me from myself.
« on: January 09, 2023, 09:00:27 am »
Looking to start on a stereo poweramp. I initially sourced parts for a mesa 50/50 style build but the schematic for that is too blurry for me to safely use.  There is a schematic posted on this site. I have a question about this schematic i have circled some traces.  Are these grounds or all tied together then run into a 47k resistor to ground?
Re: Power amp schematic on this site question
« Reply #1 on: January 09, 2023, 09:10:33 am »
Those are not grounds. They are all tied together then run into a 47k resistor to ground.
Offline joesatch
« Reply #2 on: January 09, 2023, 09:15:32 am »
Thanks, what would i change to use EL34's (2 per channel)  and is there a Negative Feedback option? i will swap that giant resistor with a choke
« Reply #3 on: January 09, 2023, 09:18:20 am »
Start by looking at a Marshall 50 watt schematic.
What giant resistor???
« Last Edit: January 09, 2023, 09:20:44 am by sluckey »
Offline joesatch
« Reply #4 on: January 09, 2023, 09:25:27 am »
marshall has a LTP this looks different. the resistor is a 10watt 150 ohm. I have a choke.
« Reply #5 on: January 09, 2023, 09:31:39 am »
It may be drawn differently but it is the same except it has NFB added. Look at Hoffman's 50W Marshall. It's drawn the same style as his 18W stereo poweramp.
You cannot replace that 10watt 150Ω cathode resistor with a choke!!!
Offline joesatch
« Reply #6 on: January 09, 2023, 09:39:14 am »
what's that resistor do? that must be an el84 thing. Can i take that 47k to ground resistor and connect it to the 8 ohm tap on the OT instead?
« Reply #7 on: January 09, 2023, 09:46:48 am »
LOOK AT HOFFMAN'S 50W MARSHALL SCHEMATIC!
Offline joesatch
« Reply #8 on: January 09, 2023, 09:59:15 am »
  I will study the your schematic and try to incorporate the two
« Last Edit: January 09, 2023, 10:09:42 am by joesatch »
« Reply #9 on: January 09, 2023, 10:33:44 am »
All you need...
Offline joesatch
« Reply #10 on: January 09, 2023, 11:25:33 am »
What do you think about adding this gain stage before each channel ? This is what the mesa 50/50 has
« Last Edit: January 09, 2023, 11:32:42 am by joesatch »
« Reply #11 on: January 09, 2023, 11:33:37 am »
I don't think it's necessary. Won't hurt to include if that's what you want. .1µF input cap is way too big.
« Last Edit: January 09, 2023, 11:35:38 am by sluckey »
Offline joesatch
« Reply #12 on: January 09, 2023, 12:01:53 pm »
Thanks again, i'd like to  include an input level control. I have gone through many power amps for guitar schematics and they all have a triode stage before the PI. I guess i will use it and put a 22nf. appreciate your help.
« Reply #13 on: January 09, 2023, 01:57:01 pm »
this is for guitar, not audio?
in either case, if you have a "proper" pre-amp, as Steve pointed out, not necessary.
if it's for guitar then maybe as an OD stage
for audio I like that stage to be a CF
Offline joesatch
« Reply #14 on: January 09, 2023, 02:01:52 pm »
It is for guitar but i would like it to be clean and not overdriven.
Offline joesatch
« Reply #15 on: February 15, 2023, 10:39:23 pm »
Getting things together. working on arrangement of parts in this 2U case. like this is close to the mesa 50/50. Anyone have experience with 120v fans like i have in here?  Most of the poweramps i see use a 12 vdc fan.
Offline joesatch
« Reply #16 on: February 25, 2023, 01:26:37 pm »
Tidying things up. It works!
Offline joesatch
« Reply #17 on: February 28, 2023, 08:30:29 am »
One of my 6l6 wxt+ red plated.  Gonna chalk that up to a bad tube that thing always biased way hotter than the rest.  I've ordered a new set.  What is the effect of having a high B+ supply for the LTP?  I'm measuring 400vdc.
« Reply #18 on: February 28, 2023, 08:47:48 am »
More headroom. Several of the big Fender amps use 450V.
