September 17, 2026, 06:48:19 am
Hoffman Amps Forum image Author Topic: Recording/Headphone outputs  (Read 5054 times)
Offline hylaphone
« on: January 09, 2023, 02:16:23 pm »
Hi folks, I've looking at implementing something like the attached schematic from Kagliostro, in a little micro amp I've built.
Will this still work if I have NFB fed from the secondary?
And do the recording and headphone outs pass full audio frequency? I'm not sure how to calculate that. If not, how would I scale up the components?Thanks very much!
Re: Recording/Headphone outputs
« Reply #1 on: January 09, 2023, 04:01:26 pm »
does your uAmp pass full audio?
I did the math 40yrs ago, not gonna happen again  :icon_biggrin:
Just looking, it'll probably pass whatever comes out of the amp
Offline hylaphone
« Reply #2 on: January 09, 2023, 05:30:32 pm »
haha I don't blame you! :icon_biggrin: Yes it's for bass guitar, 30Hz - 15kHzIf I have NFB coming from the secondary, will that be affected?
Offline nandrewjackson
« Reply #3 on: January 09, 2023, 09:50:43 pm »
I'm guessing the thick black line that r80 is connected to us a ground? I've never seen it drawn that way before.
« Reply #4 on: January 10, 2023, 04:57:23 am »
i seldom use NFB, so  :dontknow:
yes, ground
« Reply #5 on: January 10, 2023, 05:08:38 pm »
NFB should only make things better, why fear it? Though not a lot of NFB in a guitar amp.
The fat line between the jacks has to be Ground to work as expected.
Both output have high-cut filters. Raw/naked geetar has annoying highs. But you can switch-out the caps if you want "all of it", as when you have a fancier cab-sim in the system. (The coil won't make a lot of difference without the cap.)
Offline hylaphone
« Reply #6 on: January 11, 2023, 10:40:20 am »
AH! I see it now, thanks guys.
