September 18, 2026, 04:33:03 am
Hoffman Amps Forum image Author Topic: Ampeg V4 Bias Issues  (Read 13973 times)
Offline AHeck
« on: January 13, 2023, 04:57:28 pm »
I'm working on my Ampeg V4 and I'm getting a considerably higher Bias voltage of -62VDC from 253VDC instead of the specified -52VDC.  I've checked resistor values and they are very much inside of tolerance. I've included the circuit schematic and would not only appreciate guidance to get the voltage in spec, but also a basic explanation of how the circuit works to drop the voltage.
As it stands now, I am running two 6550s with the out impedance switch on the amp set to 4 OHMS and my Dummy Load Box set to 8 OHMS to compensate for only using the two output tubes and I've changed the screen resistors to 1K.  The math I've done indicates that each tube is cruising at 100mA, or 120% dissipation.
I wouldn't think that the types or number of tubes being used would have any bearing on the bias voltage, but I'm often times wrong, so please school me on how I'm wrong.  I've a matched quad of 6L6GCs in transit and would feel foolish if I were to make any changes that were unnecessary considering the imminent tube swap.
The reason for only using the two tubes is that the amp (which works perfectly in a rehearsal setting) has twice blown the 10A internal fuse during gigs taking out one tube upon each occurrence, two gigs at the same venue actually.
Any correspondence would be welcome.  When functioning, the amp is very, very dead quiet and has an amazing tone, but that's all for naught when not functional.
Thank you all, very much.
Offline AHeck
Re: Ampeg V4 Bias Issues
« Reply #1 on: January 13, 2023, 05:02:50 pm »
I'm not able to post the schematic right now, but will try later.  Sorry
« Reply #2 on: January 13, 2023, 05:03:01 pm »
I'll double check, but -62 is a colder bias than -52
the closer to zero you get the hotter the bias.
what parameters did you use to do the math?
Offline AHeck
« Reply #3 on: January 13, 2023, 05:08:40 pm »
The resistances from the used pins 3 to output transformer center tap both came in at 61 OHMS and the Voltage drops associated both came to 6.1VDC.  Did I miss something with only running one tube per side? Thanks for the reply.
« Reply #4 on: January 14, 2023, 05:19:17 am »
here's the schematic link
Ampegv4poweramp.pdf (el34world.com)
with the PA tubes out, AND the amp in standby
measure the vdc from pin 5, tube side of socket, to chassis ground
IF it's my amp, I would put 1 ohm resistors from PA tubes, pin 8 to ground to make measuring tube current a safe, no-brainer.
Offline AHeck
« Reply #5 on: January 14, 2023, 01:33:10 pm »
487V
« Reply #6 on: January 14, 2023, 02:05:54 pm »
 :laugh:
guessing your 4 and the one I linked ain't the same.
pin 5 on the schematic I linked is G1, where the bias volts wind up.
how bout re-doing with whatever your PA tube grid is
« Reply #7 on: January 14, 2023, 02:40:15 pm »
A better guess might be... WRONG PIN!   :wink:
Offline AHeck
« Reply #8 on: January 14, 2023, 04:30:14 pm »
No sir,  I'm probing pin 5, when I flip the standby switch closed, voltage at pin 5 goes from 487vdc to -62vdc.
Offline AHeck
« Reply #9 on: January 14, 2023, 04:42:13 pm »
Looking at the schematic, and please forgive/correct me if I/m wrong, with the standby switch open, the 56K and 75K resistors and the two 10uF caps from the bias circuit disappear leaving only the .047uF coupling cap, the rectifier diode and a 10K resistor in series with the 253VAC from the PT and the 100K resisters in advance of the grid.
« Reply #10 on: January 14, 2023, 05:04:23 pm »
Oops. Sorry.
« Reply #11 on: January 15, 2023, 05:17:51 am »
I missed the float when the amp is in standby.  with the switch open, there is no ground for bias supply, so the tubes "float" to B+
I think, it's early and I'm hungry!
« Reply #12 on: January 15, 2023, 07:58:41 am »
Schematic link?
« Reply #13 on: January 15, 2023, 09:33:24 am »
reply #4
« Reply #14 on: January 15, 2023, 10:50:43 am »
Ahh, I see the issue now, I’d assumed that the standby switch was in the positive supply feed.
« Reply #15 on: January 15, 2023, 11:15:10 am »
with that configuration, if the caps are from the 70's,'80's, maybe early '90s, I can see how it could pop a fuse.
Offline AHeck
« Reply #16 on: January 15, 2023, 11:30:29 am »
Thanks for sticking with the thread. I've replaced all the power supply caps and had very good performance from the amp for several months.
Offline AHeck
« Reply #17 on: January 15, 2023, 11:32:45 am »
Also, I'm pretty jazzed that I was apparently kinda right about the bias supply, but isn't putting all of B+ to the grid weird?
« Reply #18 on: January 15, 2023, 01:16:59 pm »
B+ isn't on the grid.  The grid has no "reference" since ground is "turned off"
you will find B+ on everything until ground gets turned back on
Offline 66Strat
« Reply #19 on: January 15, 2023, 02:05:34 pm »
Quote from: shooter link=topic=29809.msg328336#msg328336 date=T
Where is the ground reference? The only ground references that I see are the power tube cathodes and the  output transformer. My old eyes see the bias referenced to the neutral leg (roll the dice) of the power transformer AC winding.
Regards,
JT
« Reply #20 on: January 15, 2023, 02:32:55 pm »
See pic. The FWB negative side is the power ground. Plates and screens are always hot. The other green grounds are controlled by the STBY switch.
Offline 66Strat
« Reply #21 on: January 15, 2023, 03:25:52 pm »
I don't understand the ground scheme. Is this a floating ground? On my Fender Concert, the FWB rectifier has a chassis ground reference as indicated in the circle. I don't see a chassis ground reference on the SVT. The ground reference controlled by the standby switch goes to the ground switch with a .047 uF capacitor to block DC.
Regards,
JT
« Reply #22 on: January 15, 2023, 03:43:49 pm »
I bypassed the standby switch on my V4 for same reason. IMO, disconnecting OT CT would have been best for these amps.
--Pete
« Reply #23 on: January 15, 2023, 05:41:05 pm »
I don't understand the ground scheme. Is this a floating ground?…
That schematic shows a 2 prong era amp.
The one below shows a 3 prong era amp, with a mains safety earth, and also the chassis connection that’s not marked on the previous schematic.
https://el34world.com/charts/Schematics/files/Ampeg/Ampeg_v4_vt22.pdf
« Last Edit: January 15, 2023, 05:51:22 pm by pdf64 »
« Reply #24 on: January 16, 2023, 02:01:27 am »
maybe there were some flameouts between the '71 version and the '77 one  :dontknow: , or Nader was in the building :icon_biggrin:
« Reply #25 on: January 16, 2023, 03:54:59 am »
So if there’s 487V on the grids in standby, what’s happening to the bias supply caps?
« Reply #26 on: January 16, 2023, 05:08:47 am »
the 487v is "fantom" voltage i believe, since the Bias supply has no ground until the switch closes.
« Reply #27 on: January 16, 2023, 08:41:30 am »
I think it’ll depend where exactly the meter is connected to, ie the switched HT supply common or chassis common ( = the bias supply common).
To go up high, I think it will have been connected to the switched HT common.
« Reply #28 on: January 16, 2023, 09:39:52 am »
it hurts my brain to think that hard  :icon_biggrin:
all I know from experience, when "everything" measures B+, ground is missing somewhere.
« Reply #29 on: January 16, 2023, 09:45:02 am »
Of course it's missing. The STBY switch did that.   :icon_biggrin:
Offline 66Strat
« Reply #30 on: January 16, 2023, 10:57:09 am »
In the schematic posted by Shooter in reply number 4 there is no chassis ground reference. This schematic was for a 1971 V4 drawn by Joe Piazza. Was this an error in the schematic?
The schematic posted by pdf4 in reply number 23 for a 1977 V4 shows the chassis ground connection.
Regards,
JT
« Reply #31 on: January 16, 2023, 11:03:00 am »
I think it must have been.
The node that sluckey used the green highligher on in the attachment in reply #21 representing chassis common.
« Last Edit: January 16, 2023, 11:05:40 am by pdf64 »
Offline 66Strat
« Reply #32 on: January 16, 2023, 11:34:50 am »
I don't see it. The schematic that Sluckey highlighted in post number 20 is the same one that Shooter posted, hence my question regarding floating ground in post number 21.
Regards,
JT
« Reply #33 on: January 16, 2023, 11:55:56 am »
I got the stby switch, what i'm strugglin with is explaining "why" G1 measured 487.
I'm not a real engineer, i just played one in the field  :icon_biggrin:
« Reply #34 on: January 16, 2023, 12:28:02 pm »
I wonder what that voltage would read if there was a 22K resistor tied across the meter probes.
« Reply #35 on: January 16, 2023, 05:35:28 pm »
 :hijack1:
This thread inspired this thought.  un-hijacking
Offline AHeck
« Reply #36 on: January 16, 2023, 07:32:03 pm »
This has been very interesting and I'm wondering if there are any tests I could do here to help answer the question of why there are 487V on the grids such as testing using different ground points with standby and the ground switch in different states.  I'd also still like to know why the two 6550s are running at 100mA, or even if that is correct. Regardless, thanks for showing up and helping out.
« Reply #37 on: January 16, 2023, 11:41:55 pm »
The only thing the tube cares about is the Grid-to-Cathode voltage. In the V4 Standby the cathode is also near 487V and the tube feels "no" voltage. (Some measurement error due to meter loading.)
As for the 100mA... put 1 Ohm resistors in the cathode circuits, then you'll Know.
« Reply #38 on: January 17, 2023, 09:15:19 am »
I think this is the original Ampeg V4 schematic
With reference to chassis common, I can’t see how the pin 5 grids could be up at high V DC in standby  :dontknow:
Could that be rechecked?
To cool down idle anode and cathode current, the value of R50 or R49 could be increased.
« Last Edit: January 17, 2023, 09:20:12 am by pdf64 »
« Reply #39 on: January 17, 2023, 10:31:11 am »
there is NO high VDC on pin 5 in standby, the meter however with it's huge 10meg impedance(?) thinks there is.
Sluckey mentioned a 22k between black and red while making the measurement.  doing that should make the meter believe in reality.
« Reply #40 on: January 17, 2023, 11:07:29 am »
My concern is due to reply #6, which indicates 487V from pin 5 to the chassis.
The schematic shows a total of 222k of resistance between pin 5 and the chassis, with the cathode being directly connected to chassis.
I agree that the grid can’t be 487V with respect to the cathode; if it was stray voltage with no current sourcing capability though, the grid would be forward biased and shunt it to the chassis. Hence to me, things don’t seem to square up, so it would be nice to confirm that pin 5 standby voltage, with respect to the cathode / chassis common.
I suspect that the reading was taken with respect to the HT rectifier negative terminal node (ie the switched common of the HT supply).
Whatever, it’s a very good idea for the control grids to have their normal bias voltage whilst in standby. As otherwise, the valves will momentarily pass heavy current when standby is flipped to operate mode. Due to it taking a few seconds for normal bias voltage to be established.
« Reply #41 on: January 17, 2023, 11:27:59 am »
I understand your concern, i've chased many rabbits in my life!  I suspect even the design engineers figured it out by '77 based on the schematic you posted.
It really boils down to do i want to re-design the amp, or keep it '71 original.  that is what folk like us get paid for "Hey can you....sure $19.99"  :icon_biggrin:
