September 18, 2026, 11:11:46 pm
Hoffman Amps Forum image Author Topic: Blackface Vibrochamp tremolo  (Read 4823 times)
Offline isaac_teller
« on: January 25, 2023, 06:49:28 am »
Hello. I built a Vibrochamp clone. It sounds just dandy with one fairly minor problem(situation). The tremolo doesn't kick in until the intensity pot(25KA) is at about 80-90% clockwise. Speed knob works fine afterwards. Would a change in pot value correct this? Thank you.
Offline Esquirefreak
Re: Blackface Vibrochamp tremolo
« Reply #1 on: January 25, 2023, 07:03:53 am »
Pot taper matters. RA25K pot will probably get the wobble happening earlier on the dial, rather than the A25K.
Do you have a decent voltage swing on the LFO tube?
/Max
« Reply #2 on: January 25, 2023, 07:14:58 am »
I'd have to order a RA25K as I don't have one right now. Could I substitute a 25K linear in the meantime? Or maybe use the circuit for the AA964 tremolo and ground the end that would normally go to the bias supply?
« Last Edit: January 25, 2023, 07:18:16 am by isaac_teller »
« Reply #3 on: January 25, 2023, 07:39:06 am »
For a temporary fix just swap the wires on the outside lugs of the pot. Intensity will work backwards but should be spread out more evenly over the knob rotation.
« Reply #4 on: January 25, 2023, 07:50:57 am »
Thank you!!
