September 17, 2026, 07:07:44 pm
Hoffman Amps Forum image Author Topic: DC heater scematic recommendatoins  (Read 6379 times)
Offline Jonas
« on: January 29, 2023, 08:16:12 pm »
Does anyone have a DC heater circuit recommendation?
Offline glass54
Re: DC heater scematic recommendatoins
« Reply #1 on: January 29, 2023, 08:36:13 pm »
Hi Jonas,
For clarity and your needs, how many tubes (I'm assuming preamp tubes only) or just first tube on input?
It matters  :laugh:
Regards,
Mirek
"To measure is to know"
Offline acheld
« Reply #2 on: January 30, 2023, 10:12:28 am »
Scroll to the bottom section and read . . .  http://www.valvewizard.co.uk/heater.html
« Reply #3 on: January 30, 2023, 11:43:57 am »
The way Merlin shows the filament lead dress is interesting and may be helpful to me in a recent build. Thanks for the link.
Offline Jonas
« Reply #4 on: January 30, 2023, 04:32:36 pm »
thanks Mirek, and good question.  I have always considered the PI to be part of the power amp so would it be best practice to keep this tube on AC?
Thanks for the link - is it best to keep DC heaters limited to V1 only?  I see the diagram shows only one tube and I'm reading the notes regarding the amount of filtering required and the extra current demands (600mA).
Maybe the better question is when would you want to use DC heaters?
Thanks again!!
Offline acheld
« Reply #5 on: January 30, 2023, 04:58:53 pm »
Merlin's paragraph says it all for me.
For whatever reason, heater induced hum has not been an issue in my builds, so I have not resorted to the bother of DC heaters.
 :icon_biggrin:  I have other demons to slay -- namely unwanted high frequency oscillations . . .
« Reply #6 on: January 30, 2023, 06:13:15 pm »
... Maybe the better question is when would you want to use DC heaters? ...
Very high gain preamps, or when you have frequent problems with heater-to-cathode leakage in preamp tubes.
Offline Jonas
« Reply #7 on: January 30, 2023, 08:00:30 pm »
thanks, I'm not considering a very high gain preamp so I think I will stick with AC heaters.
Offline glass54
« Reply #8 on: January 30, 2023, 11:55:27 pm »
To add to HBP's advice, It's very useful to have DC heaters for Phono Preamps (RIAA), Mic Preamps and possibly Tube-based test equipment.
I have attached a simple 3 Terminal regulated Heater supply schematic that I have used successfully before.
Regards
Mirek
Offline acheld
« Reply #9 on: January 31, 2023, 10:11:35 am »
Interesting.   I've been looking for a schematic for a Phono preamp with line level out.
HiFi is a different skill set than guitar amps . .  .
Offline glass54
« Reply #10 on: January 31, 2023, 06:12:36 pm »
Off Topic Acheld but here is a link to a good project and in Polish to extend you  :laugh: http://skarabo.net/sid-21-prea-riaa.htm
If you want to PM me, for more ideas, you are welcome.
Regards
Mirek
« Reply #11 on: February 01, 2023, 03:26:16 am »
I have always considered the PI to be part of the power amp…
Well, in terms of its signal inverting function, it’s necessary for a push-pull ‘power amp’ (if you’re not using an interstage transformer to invert the signal).
But electrically, in most pp amps, it’s a preamp tube (so it’s power supply current demand is relatively small), and it takes its power supply from a separate part of the power supply circuit (compared to the power amp). So if you’re grounding the PI returns with the power amp returns, you ‘could’ be making the amp hummier than it needs to be (or not).
