September 17, 2026, 04:39:13 am
Hoffman Amps Forum image Author Topic: V1 preamp tube DC on grid  (Read 5547 times)
g-man
  • Guest
« on: February 03, 2023, 01:29:46 pm »
Deleted
« Last Edit: August 06, 2024, 03:21:00 pm by g-man »
Re: V1 preamp tube DC on grid
« Reply #1 on: February 03, 2023, 01:55:44 pm »
guessing it's not DC since it would be there with good tubes and bad
probably loose tube/socket or input jack that's iffy
« Reply #2 on: February 03, 2023, 02:04:28 pm »
bad tubes
« Reply #3 on: February 03, 2023, 02:21:53 pm »
Just to expand on that, even good valves might exhibit a tiny bit of grid current.
That’s why there’s an upper limit on grid circuit resistance.
Also, as anode voltage reduces, grid current will tend to increase.
But if with a ‘limit or lower’ grid circuit resistance there’s much VDC on the grid, eg >0.1V, then the valve might be regarded as no good.
« Reply #4 on: February 03, 2023, 02:33:40 pm »
bad tubes
And the tubes may work satisfactorily in another circuit.
g-man
  • Guest
« Reply #5 on: February 03, 2023, 02:38:40 pm »
Deleted
« Last Edit: August 06, 2024, 03:21:26 pm by g-man »
